I came up with pretty much the same numbers, but then thought whats the least you could get away with:
RB20 Block
Bore & Hone block_________________ $140 ok
Crank Grind ______________________$140 Might be able to get away without this
Full balance, rods, crank_____________$100 ok, low?
Balance and shot peen rods (set)_____$150 Leave out
ACL bearing _____________________ $200 ok
Head rebuild, hydraulic tappets_______ $250 Leave out
Basic Port________________________$500 Leave out the porting - still need the chamber work ~$200???
Arias Pistons_____________________$1,600 4AGZE - still not convinced this works tho - $750 new (forged too)
VRS Gasket kit ____________________$250 ok
ARP Rod Bolts ____________________ $480 Necessary? Are RB26 rod bolts use once? When do you need upgraded bolts in rb26's?
Head gasket - metal________________$300??
Bush rod ends suit smaller gudgeon pins$200??? dont really have any idea what this would cost
Now you have to buy a set of GTR Rods _$350 ok, seen a little cheaper
Also a GTR crank____________________$400 ok, seen a little cheaper
gtr Water & Oil pumps________________$800 used rb26 $400 both
Cams_____________________________$800 leave out, or GTR cams ~$300
Then there are things like timing belt, perhaps new idler bearings etc etc. say ~$500 in other spares and consumables
So $3,500-$4,000
  • Replies 49
RB20 Block
So $3,500-$4,000
The basic difference is Roy will find a few dollars in his budget for the odd beer and bourbon, You browny will say, "damm, I didnt budget for that! Gotta go without beer for a week!"
Any big end bolt is use once in the performance world. Well you got me excited Roy... We just bought a house and now I have a base to work on projects! So might try and put together a 2.4 for the local circuit races (Tomie piston kit bout AUD2k). Thats if I dont decide to get a boat! Check the view
Is that a realistic price for Crank / Rods (I have no idea) or would it creep up from there?
TT
Look at those views, i would like to have bought a place around Kurrajong NSW, near the Hawkesbury, but who can afford it, houses have gone up 80% in 3 years...so ill stick with bolting parts on my car.
The price for the rods and crank are prices i commonly see, they go rather cheaply these days, as there is no demand for them. You watch as ppl start bolting GTR cams into their Rb20s the prices start to go up as demand increases, same with ppl that want to rebuild RB20s, for an extra $800 you can have a 2.4L... us poor lowly RB20 owners scrounge for the hand me downs from out bigger brothers
I did a search in the fs section on here, SDU & PF for crank/rods. Prices were generally in the range of $500-700.
I'm really interested to know if the 4AGZE pistons will work easily. The bore is fine (1mm OS gives 82mm) but what about gudgeon pin location?
I need RB20 conrod length & piston crown height so I can work out where it would all sit in the block.
I agree with Roys comment regarding supply & demand. As soon as there is a thread where someone starts explaining how an oem part can be used as a cheap upgrade the prices start to jump. RB25 turbos seem to be a lot more expensive now.
very cool thread, has got me fired up waiting for my car to arrive!
i bought an r31 gts-x with the 2.4 tomei kit fitted (rb26 crank and rods) and KKK K27 turbo, has all the support mods like aftermarket intake, GTR injectors, trust high mount manifold and wastegate, oil cooler, hks ecu, fmic etc etc.
thats about all the mods i know of, as soon as it gets here i'll be throwing it on the dyno to see what it makes and how responsive it is but thats about a month away. was actually thinking i'd remove 6 of the 12 injectors and chuck a wolf plugin or remapped stocky on when it gets here as the hks ecu will be tough to find tuners for and i'm pretty sure i'll be able to run it fine without the 6 extra injectors.
if like you guys say it costs over 6000 to do the build properly then seems i got a bargain (payed $5000 for the whole car) :)
R31 was where I started, to build a classic Targa Car, but then the R31 GT® like the hot model was ¥500,000 so we ended with the HCR32.
I have just done a deal on a crank... Have to go to South Korea later in the year, will go via Japan and get rest of bits. Just hope the AUD holds up...
Thanks for talking me into it Roy!
TT
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
