hi guys my first post.
okay I've had my GTR for about 1 year now its got 85,000 km on the clock it get service every 5,000 km. I was driving tonight as normal and i noticed it wasn't making any boost, after about 30 seconds it started making boost again so i kept diving cause i had to to get home then next minute the engine dies, i herd a noise before it died but with the loudness of the exhaust i couldn't tell you what it sounded like. I pulled over and tried starting it again but nothing just winds over and I can see one of the cams rotating, i can also hear it got some compression while winding over. So it's on the side off the road around the corner from my place there's no oil or anything on the ground where it happened or where it sit's.
Would love to know what you guys thought cause she's my baby ! .
https://www.sau.com.au/forums/topic/425122-broken-r32-gtr/
Do share your findings?
Cam failure?
'Box failure?
Electrical?
well i rang the mechanic and asked him whats wrong with it and he said its got no compression and the timing belt is good so asked him again whats wrong with it and how much has that cost and hes said i dont know and my bill is up to
$220 i said dont worry about it a take it home figure it out myself ffs. so im thinking one of the cams has moved on the cam gear im gonna look at it saturday and ill let you know. all up ive spent $340 and still dont know whats wrong with it :(
https://www.sau.com.au/forums/topic/425122-broken-r32-gtr/#findComment-6861296
yeah its weird it just stoped all of a sudden so.. and also im a mechanice i just didnt have time at that stage to look at it lol. i live in townsville .
sorry, but surely if youre a mechanic, wouldnt you have gotten it towed straight home?
why did you take it to another mechanic?
oh, cams cant 'slip/spin' as they are located by the retaining bolts.
if all the bolts snap, I suspect the gear would drop off.
possible you have a split boost pipe?
as already mentioned, skipped teeth(timing belt jump) on one of the cams.
had this happen to me.
timing belt idler collapsed on start up.
low on comp.
new belt and pullies.
and it was fine.
you were driving, so hopefully no internal damage.
https://www.sau.com.au/forums/topic/425122-broken-r32-gtr/#findComment-6864653
okay guy, like i have said i didn't have time to look at it at that stage and thought if i took it to a guy that works on them all the time he would be able to tell me what's wrong with it but he couldn't .
so I've had a look this morning and the exhaust cam is out one tooth retarded and don't know if the belt has moved on the crank gear.
so I'm asking you guys if that would stop a RB26 from running, because I'm not a GTR expert and don't try to be, still learning about them every day.
I'm going to set the timing up right and see if it runs but that's next weekend job.
thanks guys.
Edited by nammmy
https://www.sau.com.au/forums/topic/425122-broken-r32-gtr/#findComment-6865905
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
