So it stopped running while you owned it or it has never run while you owned it? Was there any significant event that caused it to stop running?
First things first: check for fuel pressure, check for injector pulse and check that you have spark. On an RB you can simply unbolt the CAS and turn it by hand. You can then hear the injectors click and watch plugs spark without the motor cranking.
Next check for compression. I have a feeling it may have bent some valves when it slipped the belt, but i am only speculating.
Verdict: if it has fuel pressure, injectors pulse, has spark and has compression then it SHOULD run. Cam timing could stop it if it were majorly out, as could major intake leaks.
Outside of the above you should be able to find the issue with those tests.
suggest you fit a timing belt kit and try to start the car? IF the motor is f**ked you would need those parts anyway as part of a rebuild , once you have got it all back together then turn it over by hand first
yeah it stoped running while i was driving and ive found its a tooth out on the exhaust side.
Yep that's my plan for next weekend get it timed and see if she'll run.
rb engines, like any other 4 stroke engines.
if it has skipped a tooth or possibly more, could definitely stop it running.
yeah thanks mate i wasn't sure if the rb's were really sensitive to being a tooth out or not but yeah still could be more teeth out on the crank.
maybe check the sprockets on the inlet and exhaust cams and find out what may have causedthe belt to jump otherwise it may do it again
  • Like 1
yeah next weekend when i pull it all apart ill see if i can see the cause of the problem and put a new timming beld kit on
welcome to the world of low mount turbos lol
If u got access to a hoist will help from the bottom. Take this opportunity to change the turbos or dumpipes if u need to while its being taken apart
Is that what the problem was, a blown propellor?
yeah the rear propeller on the rear turbo :(
everyone told my what a flamin mongrel of a job it is but agh it couldn't be that bad but it is !! hahah
what im trying to do is take the head off in the car but i think the intake side is going to be even harder.
So is it turbo or timing (cam gear) related? Or both?
Whys the head coming off?
its turbo and compression related thats why im taking the head off to see what kind of damage there is and to see what course of action im going to take rebuild or just get it going till i have enough money to do a full rebuild
I managed to pull the rear turbo off. Short 13mm combo spanner helps with the dump pipe; tedious as hell.
How the hell did you get the front turbo off? It looks impossible lol
haven't got it off yet almost though and i know what you mean i was sitting there yesterday thinking what the actual f**k lol
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
