So it stopped running while you owned it or it has never run while you owned it? Was there any significant event that caused it to stop running?
First things first: check for fuel pressure, check for injector pulse and check that you have spark. On an RB you can simply unbolt the CAS and turn it by hand. You can then hear the injectors click and watch plugs spark without the motor cranking.
Next check for compression. I have a feeling it may have bent some valves when it slipped the belt, but i am only speculating.
Verdict: if it has fuel pressure, injectors pulse, has spark and has compression then it SHOULD run. Cam timing could stop it if it were majorly out, as could major intake leaks.
Outside of the above you should be able to find the issue with those tests.
suggest you fit a timing belt kit and try to start the car? IF the motor is f**ked you would need those parts anyway as part of a rebuild , once you have got it all back together then turn it over by hand first
yeah it stoped running while i was driving and ive found its a tooth out on the exhaust side.
Yep that's my plan for next weekend get it timed and see if she'll run.
rb engines, like any other 4 stroke engines.
if it has skipped a tooth or possibly more, could definitely stop it running.
yeah thanks mate i wasn't sure if the rb's were really sensitive to being a tooth out or not but yeah still could be more teeth out on the crank.
maybe check the sprockets on the inlet and exhaust cams and find out what may have causedthe belt to jump otherwise it may do it again
  • Like 1
yeah next weekend when i pull it all apart ill see if i can see the cause of the problem and put a new timming beld kit on
welcome to the world of low mount turbos lol
If u got access to a hoist will help from the bottom. Take this opportunity to change the turbos or dumpipes if u need to while its being taken apart
Is that what the problem was, a blown propellor?
yeah the rear propeller on the rear turbo :(
everyone told my what a flamin mongrel of a job it is but agh it couldn't be that bad but it is !! hahah
what im trying to do is take the head off in the car but i think the intake side is going to be even harder.
So is it turbo or timing (cam gear) related? Or both?
Whys the head coming off?
its turbo and compression related thats why im taking the head off to see what kind of damage there is and to see what course of action im going to take rebuild or just get it going till i have enough money to do a full rebuild
I managed to pull the rear turbo off. Short 13mm combo spanner helps with the dump pipe; tedious as hell.
How the hell did you get the front turbo off? It looks impossible lol
haven't got it off yet almost though and i know what you mean i was sitting there yesterday thinking what the actual f**k lol
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
