Hey all,
Posting on behalf of a mate.
He has a 33 GTST and has the following mods (track only car)
1000cc injectors
Power Fc
Profec 2 boost controller
Walbro E85 pump
Cam gears and cams
z32
Stripped the car completly.
Runs slicks on the rear
Looking at what turbo and what top mount manifold to use?
Plus what forward facing to use?
Will a bigger throttle body be needed?
What he is setting it up for is 1/8th mile dragging.
Hes after a turbo for excellent response and mid range power.
The engine will be rebuilt if / when it goes bang.
Not chasing any specific power goal, just decent times over the 1/8th mile
What options are there?
Only needs to pull hard from a standing start to the end of an 8th mile!
Any other mods needed to?
https://www.sau.com.au/forums/topic/425145-rb-25-turbo-choices/
most cars on the strip are built for bigger power and even plenty of these street cars are the same and have much bigger setups. In yous instance you are talking 1/8th so the question has to be asked is why?
whats the point of the 1/8th? where you heading with the build?
whats quick on 1/8th is going to be usless (or just about) on 1/4
to be honest because the only venue i have to drive my car is an 1/8 mile track.
plus the car will be used for the occasional hill climb and the sorts.
So its more about response and excellent mid range, without running out of puff
Its just hard reading and getting ideas as there is nothing on here for what im looking for.
Its a strickly track only car also, so dont car about a rough idle for cams or a pig to drive etc as its out on the track a handful times a year etc etc
Gtx3071 on e85. Plazmaman plenum with his 72mm throttle body. Should be good for 350rwkw with killer response. Nitrous is awesome set up correctly. Unsure why people dislike the idea of using it. What's a nitrous kit worth now days?
I don't personally have that setup but micko on here did and from all reports pulled like a freight train all the way through. Maybe someone that actually know micko and went in it can explain more? Um I think he made 335rwkw on e85 internal gate version .82! Also on the stock mani aswell.
Lol @ top end, its an 1/8 mile you wont get half way though third gear,
just get a hiflow..stock plenum and everything...it will be just as quick for what you need...
the money you save put towards your suspension setup, tyres and practice runs because that's what will make you fast...
Anyway I know nobody will take any notice of this post so potato...
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
