Just been thinking of using multiple throttle GTR plenum. However Im not sure if the runners for a R34 and 33 are the same. I could do away with cutting the runners by machining a adapter plate using RB26 N 25 gaskets as templates. However using an adapter would mean that i have to cut and re weld the water outleet so it doesnt crush the VCT solenoid. Using 34 runners would be good because i still have the same injector sitting angle. The downside is that i cant find any 34 lower runners. So it brings the question, are the 33 and 34 runners the same especially on the way injectors sit and fuel rail mounts. From looking at a few pics they dont look the same but when you look at the gaskets, they have the same part number.
Are the manifold o rings also 14mm
Do the 33 injectors sit the same way as 34 (o -rings and sitting angle) but atleast i know i can top put on top feed injectors on the 33 intake manifold given that i change the rail aswell. I just dont want to downgrade from an intake plenum which was better.
I dropped by Jaycar and saw a cheap set of 6000K HID bulbs, thought it would be good to restore the xenon lights so i got to task.Had to take my front bumper off to access the wires that were cut during compliance to stop the ballasts from supply energy to the light plug.
It was just a matter of connecting wires back together
But then after hours of trying to figure out what was wrong with the LHS light i swapped the ballasts and the light still worked indicating the supply cable within the light is Kaput. Not sure if i really want to open the inside of the light as its the one i use. Might just get a connector plug it onto the ballast and feed it through the side of the housing to the light
Yeh man, it's easy. Take off the 5 spring clips on the housing, and undo the two little screws on the park-light side. Remove all the plastic bits that you can, tuck all the wiring inside the housing, and pre-heat oven to 100 degrees, then headlight in for 8 minutes or so. Keep an eye on it in the oven and nothing will go wrong. Then use a screw driver to pry the lens away from the housing. If you need to pull too hard then put it back in the oven for another couple of minutes. Just do it slowly and you'll be sweet.
To put it back together, just reverse the process :thumbsup:
Whilst im waiting for the tuner to get back, I got a hi flow turbo for a steal price, as im not willing to stay at 180kw while i source out options for the turbo ill use. So the hi flow will be the super sub while I find a good contender to use. Have gone through so many compressor maps I can probably tell you the name of the turbo without even looking :P.
Im tempted to bolt up the hi flow but without tune it will probably run really bad. As for the injectors if i manage to loan a Nistune consult cable ill be able to change the injector size and latency so i can still drive it (My Daily) to the tuners otherwise ill just resort to getting it towed to the tuner.
meant as in drive it for a few weeks till the tuner is back, however I wasnt sure about driving it offboost on the day i take the car.Its certainly something i will experiment doing while i have the stocker but with the hills in my area. It will be quite interesting.
  • 1 month later...
Thats good so you just gotta transfer your stuff from the 33.Except for a few things that wont work with Neos hopefully wont be much.
Very nice man good to see you a doing a thread on the build... Thumbs up!!
I see you learnt the hard way about spending a little extra on stand alone ecu's huh? Good work keep it up
I donno if I will be building mine like yours but chasing around the same figure.If it pops I'll get another stockie and repeat and transfer. If I had known from the start I would have got a standalone only a few extra dollars.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
