  On 08/08/2013 at 10:41 AM, B-rice said:
How effective are the fuel coolers though,are they like intercoolers which are about 85-90% effective. I guess it also depends with where theyre mounted too.
Check my build thread for pics (probably back 10-15 pages) mine is setup like larger version of the Z-tune one (I think that's what Bobby said) but it's mounted under the spare wheel in a small diffuser type setup... Pretty sexy!
Finallly got to install my flex fuel sensor, its all hooked up and everything but i havent tuned the car for E85. So at the moment im just finishing off my fuel system. All i have to do is upgrade the old fuel lines so they wont corrode, when i do the full transition to E85. Currently my fuel temps are lingering around 20-36 degrees during light commute duties. Not sure if i wasted money with the fuel cooler. Its use might come into play during the summer season.
Managed to fab up a simple bracket to hold the flex fuel sensor next to the fuse.Had to remove the brake cylinder stopper as im still in the process of making spacers that will go inbetween the BCS and the brake for the sensor.
I should be running outer space quite soon when I fit a new plenum, hopefully not too much.
Another update, got my wheels back from powdercoating. Gotta say they look brilliant.The best part is that I only spent $40 a wheel to get them painted.
been trying to remove the turbo so that i can put on new gasket to stop the scream while on boost. The worst part about this is taking out the lower nuts. Its one b*tch of a job. Anyone have any ideas or techniques of how to remove it. Was thinking of grinding off a bit of the spanner for it to fit in. I would like to know how the japs fitted it in the factory because just putting on the cement on the leak was a challenging task
Also if i did remove the oil and water lines on the turbo. Does that mean that I have to bleed the coolant system again and probably do an oil change too. Im contemplating doing this, or trying to fit the gasket without removing the hard lines.
It's easy enough to do with the right tools. But the bottom nuts are much easier to do from underneath.
As for removing the lines, yes you will have to bleed the coolant but you shouldn't need to do an oil change. But should be easy enough to change the gasket without removing the lines.
  • Like 1
Hanaldo always to the rescue, thanks.I managed to remove the bottom ones by going underneath. I noticed whoever owned it before didnt do them up properly, the metal tabs where the only thing holding them from getting undone
No problem mate, I remember how frustrating a job it was the first time I did it. It does get easier! I can have the whole hot side off in about an hour these days haha.
Was the metal tab on properly? They are prone to undoing themselves over time, so they may have been done up but just loosened up a bit.
Hey man, I got them done by mobile fabrications. If you can sand blast them yourself it will be $40 per wheel but they can do the blasting plus painting for $88. From the results they did on mine i think they know their shit. They even had experience with forged wheels because you could wreck them if overheated.
Im getting my Tune done by Autotech. But have also been considering taking it to ultimate tunes. ESP said Vipecs cannot do flex tune (it was a diplomatic way off saying he cant do it). Im learning towards Autotech because he has some extensive experience with Skylines. Depends what you have also and the quality of work your after.
Lol. I started the car 40mins ago to set the gasket sealant and voila you come up with an idea i never thought of. My next turbo change will be a topmount if the permalock i put on these doesn't come out ill just rip it all out with the manifold hehe.
Ah sweet mate, yeah the rims look great.
I would be interested to see what you reckon of how it runs on the flex fuel and how difficult/expensive it is to tune. Do they have to tune for 98 and E85 and then several points in between? I was not aware of tuners in Canberra that had extensive previous experience in tuning flex fuel and had not heard of anyone else from Canberra getting their skyline tuned for flex fuel. Based on that and the fact that I already had my power fc on the car, mine just runs a power fc and caltex E flex all the time. It has been that way for 6 months at 320 rwkw and I am pretty happy, but it just means if I ever want to go to wakefield or something I would have to load the car up with Jerry cans so I would have fuel to get home. So on my next round of mods I may change the ECU. So let us know how you go
Ed said he would tune E10,E20,30...up to E90 and 98.
Should be taking it for a tune in the next coming weeks. Just have to install the injectors but im still waiting on a rail that will fit 14mm injectors and also fit under the stock plenum. So far Plazmaman fuel rail seems like it has a chance of fitting under there. Also have to find out the correct diameter o-rings for the injector on the intake manifold. Will update you.
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
