Just been thinking of using multiple throttle GTR plenum. However Im not sure if the runners for a R34 and 33 are the same. I could do away with cutting the runners by machining a adapter plate using RB26 N 25 gaskets as templates. However using an adapter would mean that i have to cut and re weld the water outleet so it doesnt crush the VCT solenoid. Using 34 runners would be good because i still have the same injector sitting angle. The downside is that i cant find any 34 lower runners. So it brings the question, are the 33 and 34 runners the same especially on the way injectors sit and fuel rail mounts. From looking at a few pics they dont look the same but when you look at the gaskets, they have the same part number.
Are the manifold o rings also 14mm
Do the 33 injectors sit the same way as 34 (o -rings and sitting angle) but atleast i know i can top put on top feed injectors on the 33 intake manifold given that i change the rail aswell. I just dont want to downgrade from an intake plenum which was better.
I dropped by Jaycar and saw a cheap set of 6000K HID bulbs, thought it would be good to restore the xenon lights so i got to task.Had to take my front bumper off to access the wires that were cut during compliance to stop the ballasts from supply energy to the light plug.
It was just a matter of connecting wires back together
But then after hours of trying to figure out what was wrong with the LHS light i swapped the ballasts and the light still worked indicating the supply cable within the light is Kaput. Not sure if i really want to open the inside of the light as its the one i use. Might just get a connector plug it onto the ballast and feed it through the side of the housing to the light
Yeh man, it's easy. Take off the 5 spring clips on the housing, and undo the two little screws on the park-light side. Remove all the plastic bits that you can, tuck all the wiring inside the housing, and pre-heat oven to 100 degrees, then headlight in for 8 minutes or so. Keep an eye on it in the oven and nothing will go wrong. Then use a screw driver to pry the lens away from the housing. If you need to pull too hard then put it back in the oven for another couple of minutes. Just do it slowly and you'll be sweet.
To put it back together, just reverse the process :thumbsup:
Whilst im waiting for the tuner to get back, I got a hi flow turbo for a steal price, as im not willing to stay at 180kw while i source out options for the turbo ill use. So the hi flow will be the super sub while I find a good contender to use. Have gone through so many compressor maps I can probably tell you the name of the turbo without even looking :P.
Im tempted to bolt up the hi flow but without tune it will probably run really bad. As for the injectors if i manage to loan a Nistune consult cable ill be able to change the injector size and latency so i can still drive it (My Daily) to the tuners otherwise ill just resort to getting it towed to the tuner.
meant as in drive it for a few weeks till the tuner is back, however I wasnt sure about driving it offboost on the day i take the car.Its certainly something i will experiment doing while i have the stocker but with the hills in my area. It will be quite interesting.
  • 1 month later...
Thats good so you just gotta transfer your stuff from the 33.Except for a few things that wont work with Neos hopefully wont be much.
Very nice man good to see you a doing a thread on the build... Thumbs up!!
I see you learnt the hard way about spending a little extra on stand alone ecu's huh? Good work keep it up
I donno if I will be building mine like yours but chasing around the same figure.If it pops I'll get another stockie and repeat and transfer. If I had known from the start I would have got a standalone only a few extra dollars.
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
