Hey guys, I'm new to SAU.
Anyway, on friday I bought a new skyline (my first car). Before this I drove my dads automatic nissan pulsar.
On the drive home another driver swerved into my lane on a turn, and I tried to slow down and move out of the way. I lost control and ended up hitting the car. (It was an extremely wet day) Completely f**ked my bumper up and my the cheapest quote I could get was $1416.50 for a new bumper, fog light cover and bumper reinforcement. This was before I could get the car insured and hand in the vehicle transfer papers.
Just thought I'd share my bad luck.
Edited by Humma
https://www.sau.com.au/forums/topic/425152-worst-luck-ever/
If she came from an adjacent lane into yours, she is still at fault.
Get onto a traffic lawyer.
If you're in NSW, we have a list of traffic lawyers on a "Traffic Lawyer" thread.
Most don't charge for an initial consultation for a few minutes.
If the lawyer thinks that you are not at fault and have the other driver's details, your lawyer can draft a "Letter of Demand" on your behalf and go from there.
https://www.sau.com.au/forums/topic/425152-worst-luck-ever/#findComment-6848952
Which is why you always arrange a cover note before you pickup a new car.
But if you're not at fault, the other driver pays for your damages?? You don't need to involve your insurance company even if you did have one. Get three quotes, download a 'letter of demand' template and send it to the other parties insurer.
Other option, if the vehicle was still under the previous owner you could see if they feel generous enough to put in a 'not at fault' claim under full comp and nominate you as the driver, but with excess and the fee assosciated with a driver not on the policy, provably would work out much the same.
https://www.sau.com.au/forums/topic/425152-worst-luck-ever/#findComment-6848960
If he came from an adjacent lane into yours, he is still at fault.
If he/she thinks that you are not at fault and have the other driver's details, your lawyer can draft a "Letter of Demand" on your behalf and go from there.
She's determined it's my fault. Her HBF insurance called me to admit fault, to which I said I'd call them back and talk later. I'm in WA by the way.
https://www.sau.com.au/forums/topic/425152-worst-luck-ever/#findComment-6848974
Terry beat me to it.....
We said much the same with slight nuance differences hehe...
Yes Humma, it's only your bad luck if you let her wriggle out of it!
Did you hit her at the rear of the bumper OR on the side of the car?
It's easier for you to prove that you're not at fault if there are scratches on the side of her car.
https://www.sau.com.au/forums/topic/425152-worst-luck-ever/#findComment-6848986
Good news guys, got a bumper on in 2 days, can finally drive my new r33!
She ended up paying for her car, and I had to pay for mine due to no insurance. Unfortunately me being 17 cuts me no slack. However I have always had a passion for skylines and definitely did not buy it to thrash it!
https://www.sau.com.au/forums/topic/425152-worst-luck-ever/#findComment-6852908
Dude, that's not how it works.
If she hit your car; SHE is responsible for YOUR damage, as well as her own. It is irrelevant that you have no insurance. Your age is irrelevant.
You did nothing wrong; she pays. The end.
https://www.sau.com.au/forums/topic/425152-worst-luck-ever/#findComment-6853029
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
