I have bought a Stagea that smells pretty badly of mould but the carpets, seats etc all seem to be clean, dry and free of mould. I've tried to Glen20 the interior (its kills mould) but its not made much difference. What else should i try? Or should i just get the interior shampood by a detailer? Any recommendations for a detailer in Sydney?
https://www.sau.com.au/forums/topic/425153-musty-smell-no-sign-of-mould/
Chances are it was shampooed and left with windows closed...shamppoing is ok but you really need to air it out well afterwards...thats why steam cleaning is prefferable....
you an try oet it air out and keep the heater blasting to dry it out but you need to kill the mould and it could well be in the underlay.....it could be leaves or crud stuck in your vents even that's creating a pool of stagnent water...we found a drink spilt under our back seat that had made the seat foam turn mouldy..it was milk to, smelt like dead animal. :yucky:
But yeah keep looking, you need to find the source of it..GL
You can have a loan of my moisture detector Adam.
It's actually used for detecting termites behind walls - and has three settings to 'see' through brick or gyprock or timber.
So in effect, you can pass this hand-held electronic block over carpet, boot lining and such.
If you wish, I can bring it down to Earlwood on Friday.
Hi Terry,
Thanks very much for the offer, I will take you up on it. I'm intrigued by the gadget! Let me know what time suits. You could text me on Friday afternoon to fit in best with your work schedule if you like.
Hi Artz,
Yeah i saw another post about steam cleaning - will look into that, exp since its already clean just needs a spore nuking.
Terry I'm just having a chat to a pest controller friend of mine...says those meters are no good around metal as it sets it off giving false readings.
"yup. it uses electricity to detect moisture, so anything that conducts electricity will say that it has a 100% water saturation."
have you got something different to what he has maybe? they look to be relatively inexpensive to buy..
Thanks for that feedback.
They are expensive - and they're closed-shop items to inspectors.
Since I live in the Blue Mtns, I wanted one for myself 'er; my house.
To my knowledge, there's no alternative. But what I can say is, there are virtually or close to no false readings when I pass the unit over AC wiring.
Maybe I should try it on my own car first?
I can think of a few things that could contribute to the Danky smell
Mould grown from water trapped in the AC/Heater ducts or
Under the wiper Arms there is a sheild, under that sheild is a valley. It may be blocked where the water is supposed to run off.
Mould may be growing in there and smell comming through the air vents. My old 32 had a nice fungus growing in there :(
Stags have sunroofs - damp seeping into hood lining ?
Perhpas even under the centre console (carpet).
Glad the machine didn't give off any "false positives" from proximity to metal.
So it appears the cabin is pretty dry. :)
There are probably residual fungal spores that need to be evacuated - say, with a Dyson?
Maybe you can find a detailer or car yard that uses an Ozone Machine or hire one
http://www.cleaningup.com.au/content/ozone-generator-machine-hire
After that if you want you could use one of the car products and run your car with AC on
Cheers
Thanks for the the link - ill definitely give that a shot if the other one doesnt work.
No worries mate, you've helped me a fair bit over the years. (brakes is one I remember :thumbsup: )
Did a bit of research when I saw the issue you posted.
This Ozone Machine seriously seems the best method. Actually kills/removes the ION's, microbes, fungi that creates the Odours.
Cleaning masks the issue but does not rid the micro bacterial cause.
I'll definitely be using this as a Just-in-Case measure.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
    • Just chuck in an ECU, Injectors and a pair of direct fit low mount turbos, that should use to the top of your budget and give it a nice kick along. Also, don't do anything unless you don't need the car daily....if it does blow and you get another 10k bill just to get back to where it is now would you be able to come up with the cash or will it sit for 2 years like most GTRs....
    • Thank you 馃檹 I'm patient, which is good, considering the limited budget (for now) more so trying to understand where to begin the journey and you and the others have been good with that, appreciate everyone for their input 馃
    • $5-10k isn't much for reliability if your looking at more power for a RB Me, with that much money currently on hand,  I would only look at things to suit future mods, as stated, a fuel pump and ecu would be my first point of call, as well as getting the injectors cleaned and tested, maybe even replace all the coolant hoses After a little time with the tuner, they should be able to tell you how your car is running in relation to things like your ignition, cooling, and other stuff that will be picked up when it has had a few runs up on the dyno and some logs to look at Basically, get everything sorted for reliability before you start leaning on a 30 year old engine Good luck with the one and only true Godzilla, enjoy Note: for your birthday presents, ask your family and friends for lottery tickets, a 32 GTR can cost "all of the money" to make reliable power
