I have bought a Stagea that smells pretty badly of mould but the carpets, seats etc all seem to be clean, dry and free of mould. I've tried to Glen20 the interior (its kills mould) but its not made much difference. What else should i try? Or should i just get the interior shampood by a detailer? Any recommendations for a detailer in Sydney?
https://www.sau.com.au/forums/topic/425153-musty-smell-no-sign-of-mould/
Chances are it was shampooed and left with windows closed...shamppoing is ok but you really need to air it out well afterwards...thats why steam cleaning is prefferable....
you an try oet it air out and keep the heater blasting to dry it out but you need to kill the mould and it could well be in the underlay.....it could be leaves or crud stuck in your vents even that's creating a pool of stagnent water...we found a drink spilt under our back seat that had made the seat foam turn mouldy..it was milk to, smelt like dead animal. :yucky:
But yeah keep looking, you need to find the source of it..GL
You can have a loan of my moisture detector Adam.
It's actually used for detecting termites behind walls - and has three settings to 'see' through brick or gyprock or timber.
So in effect, you can pass this hand-held electronic block over carpet, boot lining and such.
If you wish, I can bring it down to Earlwood on Friday.
Hi Terry,
Thanks very much for the offer, I will take you up on it. I'm intrigued by the gadget! Let me know what time suits. You could text me on Friday afternoon to fit in best with your work schedule if you like.
Hi Artz,
Yeah i saw another post about steam cleaning - will look into that, exp since its already clean just needs a spore nuking.
Terry I'm just having a chat to a pest controller friend of mine...says those meters are no good around metal as it sets it off giving false readings.
"yup. it uses electricity to detect moisture, so anything that conducts electricity will say that it has a 100% water saturation."
have you got something different to what he has maybe? they look to be relatively inexpensive to buy..
Thanks for that feedback.
They are expensive - and they're closed-shop items to inspectors.
Since I live in the Blue Mtns, I wanted one for myself 'er; my house.
To my knowledge, there's no alternative. But what I can say is, there are virtually or close to no false readings when I pass the unit over AC wiring.
Maybe I should try it on my own car first?
I can think of a few things that could contribute to the Danky smell
Mould grown from water trapped in the AC/Heater ducts or
Under the wiper Arms there is a sheild, under that sheild is a valley. It may be blocked where the water is supposed to run off.
Mould may be growing in there and smell comming through the air vents. My old 32 had a nice fungus growing in there :(
Stags have sunroofs - damp seeping into hood lining ?
Perhpas even under the centre console (carpet).
Glad the machine didn't give off any "false positives" from proximity to metal.
So it appears the cabin is pretty dry. :)
There are probably residual fungal spores that need to be evacuated - say, with a Dyson?
Maybe you can find a detailer or car yard that uses an Ozone Machine or hire one
http://www.cleaningup.com.au/content/ozone-generator-machine-hire
After that if you want you could use one of the car products and run your car with AC on
Cheers
Thanks for the the link - ill definitely give that a shot if the other one doesnt work.
No worries mate, you've helped me a fair bit over the years. (brakes is one I remember :thumbsup: )
Did a bit of research when I saw the issue you posted.
This Ozone Machine seriously seems the best method. Actually kills/removes the ION's, microbes, fungi that creates the Odours.
Cleaning masks the issue but does not rid the micro bacterial cause.
I'll definitely be using this as a Just-in-Case measure.
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
    • That link was very helpful thank you.
    • That is the option code, not the VIN. Regardless all of that production is considered series 2: https://gtr-registry.com/en-ecr33-vin-table.php
    • Apologies if I sounded like a arse My point was that you will not be able to buy a rotisserie that suits your car, you get the rotisserie frame, and then fabricate parts to mount the rotisserie frame to the body The rotisserie side is easy, but the fabrication of the actual mounts is the tricky part, where to mount so you don't bend/twist the body, plus the geometry involved to get it to turn  If your capable at fabrication, and can work out where the C/L is in relation to the weight is so it actually can turn, you should be sweet I would love to see the progress on this just for the thought processes and fabrication
