1993 R33 Skyline GTS
I Need Help When Im Doing 100kph my speedo reads 85kph What The F*@k do i do to fix it
Someone Please Help me is there a easy fix ( Car had a Manual convertion ) not done by me Previous owner
PLEASE HELP ME Iv Got no idea what to do
ANY HELP WILL BE APPRICIATED
im running 225/40r18 and the tyre placard says to run 245/40r18s but the width of the tyre wouldnt make much of a difference
The height of the tyre, is proportional to the width.
That number 40, means 40% of the width.
IE, a 225/40 has a side wall that is 90mm
A 245/40 has a side wall that is 98mm
Once you start to factor everything in, that's a much smaller rolling distance, and it means for your car speedo saying 100KM/H, your car is going quite noticeably slower.
But I would say, you really need to convert the diff from auto to manual so that it'll all read correctly again, this would be the easiest and best way to fix your problem as well as changing tyres to the correct size.
The profile is actually a percentage if half the width.
So your 225/40 would be half of 225 and then 40% of 112.5 which is 45mm- 90mm sounded a little high for a 225/40!
Sorry but you are wrong. I can provide links to various tyre manufactures websites to verify that it is the percentage of the full width if the tyre if you like. you have to remember that the sidewall starts at the bead of the tyre. 45mm is small. For me it's the width of 2 thumbs, and given that the rim covers about 1 thumb width, I know that the tyres on my skyline were more than a thumb width from the rim
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
    • Thank you for this my turbo doesn’t have the nipple so I’ll get one installed in the turbo to Intercooler piping. I’ll get everything I need and locate it all using the information you both gave and get back with an update.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
