Nope. Home Depot lip is a rubber strip about 2 inches deep made from garage door seal, I've got some to play with but I'm not mad on the look from what I've seen.
That is, like you said, a carbon fibre splitter. Type 'g35 carbon fibre splitter' and you'll find all the vendors on 35driver - Statik Performance does one and the owner, Henry, is on the 'v35 coupe drivers' group on Facebook. The hard part will be swallowing the freight cost!
the pic you posted has a car with an aftermarket front bar as well as the splitter.
i was also interested in getting a front splitter for my car. can't find anything off the shelf though.
TopStage composites (www.topstage.com) do a very nice one but a full diffuser will cost close to $2k - a bit too much for me since the main attraction for me was how it looks! (although it needs to be functional too!)
APR performance (www.aprperformance.com) do one in the states but shipping would be very expensive.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
