Hi guys,
i got a bunch of parts ready to go in the car.
I seem to have overlooked these
Kudos-Ball-Joint-Front-Rear-Lower-BJ492-
Would mine be worn on a 1993 model by now?
http://www.kudosmotorsports.com/catalog/kudos-motorsports-ball-joint-front-rear-outer-lower-nissan-200sx-s14-s15-skyline-r32-2wd-front-only-r33-2wd-r34-2wd-p-214.html
The tie rod ends had a fair bit of play in them when I took them out if thats any indication.
Edited by sonicz
Absolutely. Better than even chance. The thing about Skylines is that things like the wheelbearings can be shagged and you don't even notice, because the overall design of the suspension gear etc is fairly robust. One part fails and the rest hold it together pretty well. You'll often not find out how bad things are until you take it apart, for the most part.
If youre pulling everything apart, might as well do the ball joints.
I replaced them all on my 96 stagea. Inner front 2 were well worn, outer 2 were borderline, rear 2 were fine. At most I wasted $50 on a rear set.
So many factors go into their life. How much weight is on them, if water and dirt gets into the socket etc.
Ok will add to the list, but I'm pretty confused here. Where can I find the inner lower ball joint to buy in addition to the outer?
Kudos only seems to have the outer like i posted above for the r33 gts t
Is this the inner one?
http://www.ebay.com.au/itm/skyline-r34-r33-gtst-front-lower-ball-joint-2wd-/251118232783?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a77d024cf
$(KGrHqUOKisE4riIyU5fBOPTQceHwQ~~0_12.JP
Also, the ball joints don't come with bushes do they?
So I need a set of these as well?
Control arm - lower inner bushing
http://www.whiteline.com.au/product_detail4.php?part_number=W53467
The more i keep looking the more parts i find I've overlooked. I Havent jacked up my car and had a proper look what parts are where, I just have a vague idea of generic suspension components in theory.
I am doing ONLY the front now consumable parts, minus the sway bars or their bushesh.
So far I have bought new.
-Tie rod ends
-Wheel Bearings
-Radius rod bushes (caster)
I am yet to order but know of
-Lower outer control arm ball joint
Shock absorber bushes (are the whiteline ones ok?)
The thing i cant figure out
The lower INNER ball joints.
Camber ARM to Body bushes.
Other parts I'm sure im missing.
Edited by sonicz
Ah it seems only the stagea, gtst-4 Gtr etc have an inner ball joint. The GTS has only one lower arm ball joint and a bush?
Im not sure why that ebay link ball joint looks different to the kudos motorsports one though.
Edited by sonicz
Ah ok, what zoomzoom said threw me off then
"If youre pulling everything apart, might as well do the ball joints.
I replaced them all on my 96 stagea. Inner front 2 were well worn, outer 2 were borderline, rear 2 were fine. At most I wasted $50 on a rear set."
Any explanation why the difference between the two ball joint pics I posted?
They are both for the same car
Edited by sonicz
Sorry. Mine is 4WD. 2WD has an outer ball joint. 4WD has an inner and outer ball joint.
What are you even trying to say? First you say that "No car has an inner ball joint.", which is completely false, now you're being a contrarian to who knows what.
I have at no time contradicted myself. There are ball joints at the outer end and there are bushes at the inner end. They are not the same thing.
ok man heres a complete list of what needs replacing. I recently went through this myself and did notice a huge difference and no more knocking noises :)
tie rod ends
tie rods ( these screw onto the tie rod ends and go straight into the steering rack)
upper inner control arm bushes
upper outer control arm bushes
lower control arm bush
lower control arm ball joint (which is the one you posted a pic of and is the only ball joint on the front end like that one for a r33 gtst)
radius rod bush
that's pretty much everything on the front end without doing engine mounts and gearbox mounts.
I'm not sure about the shock absorber bushes as I have coil overs and don't recall seeing any associated bushes with them. and with regards to greasing the wheel bearings through the abs hole it won't work as the bearing is an enclosed unit. anyone, if i'm wrong feel free to correct me
Thanks for that list.
A few Q.
What exactly is there to wear on the tie rods? I though only the tie rod ends wear. Do they connect to the steering rack via a ball joint too? I have no idea how I would replace that. Maybe pick up another low km steering rack for around $50?
Upper inner control arm bush - Do you mean the ones that are actually attached to that little light A arm and bolt to the body of the car via 2 horizontal bolts? on each side that people replace with camber adjustable arms?
If so I had a feel of mine and the A arm moved up and down nicely with almost zero play sideways or forward or back. I'm not sure if there is a point spending money on a bush there? Then again they keep camber soo...
The rest I am 100% on top of and fully understand :D
About greasing the bearings via the ABS hole. I poured some machine lubricant grease there and the noise reduced. I am not sure if it was a passage of time or there is some placebo effect but its a definite decrease. It seems likely to me a liquid lubricant would get in the bearings from there just based on that, but I wanted to confirm for sure.
I have no ABS so so theres nothing to mess up sensor wise.
Edited by sonicz
yep that's the inner control arm bushes. I personally would change them as it's hard to tell the condition of them without removing the bushes but totally up to you. I simply did it for peace of mind and knowing exactly when they've been replaced. with regards to the tie rods i'm not exactly sure if they wear or not. They're the only things i didn't end up replacing.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
