1 Fender bolts (even the top two? or are they cowling bolts?)
2 Strut tower nuts
3
4
5 Brake booster hose bracket
6
7 Fuse Box bracket
8
9 Battery clamp bolts
10 Battery terminal bolts???
11 Condenser bracket
12
13 Hood Latch Bracket Mount
14 Thermofan mount?
15 Hood Latch Mount
16 Radiator brackets
17 Crank Angle Sensor
18 Coilpack cover?
19 PTU?
20 PTU?
21
22
23 Boost Solenoid Bracket
24 Windscreen wiper motor
Edited by attila.z
  • Replies 61
Posted Images
2 Strut tower nuts
3
4
6 Throttle Linkage
7 Fuse Box bracket
8 Boost Solenoid
11
12 Condenser bracket
14 Thermofan mount?
15 Hood Latch Mount
18 Coilpack cover?
19 PTU?
20 PTU?
21 Injector Resistor Cover
22
23 Powere Steering Bracket
14. Is thermo fan
11. I don't have on my 33 GTR, so may be something on a 32GTR?
19 & 20: Are the ignitor pack on the valley cover
The bolts in the top corners as part of 1 are the bonnet brackets.
22 and 23 are power steering container as it has a wrap around bracket there's actually 3 bolts holding that
7. There are 2 metal bolts coming from fuse box.
10. Are 2 bolts holding down the fuse box itself
8. Where there are 2 bolts holding the boost solenoid, there are another 3 bolts same as the power steering bracket.
1 Fender bolts + bonnet brackets
2 Strut tower nuts
3
4
6 Throttle Linkage
7 Fuse Box bracket
8 Boost Solenoid (+3 more bolts same size as PS bracket)
10 Fuse box bolts
11 ------
14 Thermofan mount
15 Hood Latch Mount
18 Coilpack cover?
19 Ignitor pack
20 Ignitor pack
22 Power steering bracket
3 is the stock map sensor (for boost gauge) bolts. I can do a rough measure later if u want.
4 looks like the throttle cable support bracket, I guess you could call it. It just keeps the throttle cable from travelling to far AFAIK
2 Strut tower nuts
3 Stock MAP Sensor
4 Throttle cable support bracket
6 Throttle Linkage
7 Fuse Box bracket
10 Fuse box bolts
11 ------
14 Thermofan mount
15 Hood Latch Mount
18 Coilpack cover?
19 Ignitor pack
20 Ignitor pack
look good? Ill make a single kit preliminary order and send it out to get test fitted.
Before this goes much further - You need to really post in the GB section, and follow the rules of that section when starting a Group Buy so that things are transparent for all users.
There are reasons behind it and if not followed we simply cannot let this go on.
Cheers.
Cheers.
Should I leave it here though until the kit is actually finalised then ill open a proper group buy? At the moment its just information gathering..
  • 1 month later...
pm sent to 75coupe about sending a trial kit through to him this week.
I just express ordered the kit to my work, and will send it on as soon as it gets here.
He can confirm fitment/ propose any amendments to it, as well as take a few snaps for me.
Once he confirms everything is accounted for, ill put the kits together, and start a proper group buy thread.
  • 1 month later...
ok guys made some positive progress.
75coupe was kind enough to test fit the prototype R33 kit and tell me what fit and what didnt, as well as any bolts ive missed. Many thanks to him for his help. Scored himself some free bling too :) - dont worry 75coupe, ill send out the spare bits and pieces you need when this new order arrives.
The R33 kit is finished. Ive just placed an order for a bunch of them through work, and will be posting up in the Sale section in a week or so, once they arrive and are organised.
Ill probably sell them on the forum for a short while, then jack the price up and move it to ebay.
Next step is organising something for the R32 and R34.
I have a rough kit setup for the R32, and just need someone to test fit it and suggest any changes. Idea is I mail you out the sample kit free of charge, you try and fit everything, tick everything off the list that fits, if it doesnt make a note next to it why (too small, too big, thread wrong, bolt too short or too long), and if theres any brackets or anything ive missed please note them down for me too. I think the R32 kit is probably 75% complete so there isnt much left. A lot of the bolts are the same as well so youll just be able to test one of the existing bolts to see what else is needed. Once completed ill send out the extra bits to complete your kit, and get the kit organised for everyone else.
If anyone has an R32 and is willing to spend a bit of time on this for me send me a PM please.
As for the R34, I have really got a basic kit organised yet or anything. Ill have to start from scratch with that one writing down where all the bolts are, then filling out their sizes one by one as I find out.
These stainless steel bolts really make a difference to the engine bay.
Did you end up icluding the cam cover bolts in your bolt kits, i reckon owners would love the kits for that alone...
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
