Shit man, 10 sec GTS-T for 10K is stupid easy and your putting way too much into your budget.
find 400+ meter high cliff,
Push car off
ignoring drag this should get you a 9.03 second 400 meter
Collect insurance,
blow and hookers all round.
You sir.................. Are a genius!
Push car off
Collect insurance,
clap-clap-clap-eccbc87e4b5ce2fe28308fd9f
Holset hx52 turbo.
Deatchworks 1000cc s/f injectors.
China intercooler
Hybrid/nz top mount manifold.
NPC/Jim berry clutch.
Welded diff
Adaptronic ecu
Custom 4" side exit exhaust and gate
Precision 66mm gate
Nismo drop in pump
Fully sick shift light
Mickey tees slick
Front runners
Trent from cheuqed tuning for a tune.
Probably left some things out but you get the idea haha. Feel free to tell me what I forgot.
if your serious... and that's a big if.
Your best chance at a good time without alot of seat time or skills is...
You need a drag based auto.... think used c6 or 2 speed glide that has been built for drag with trans brake.
Bellhousing
Converter
Shifter
Drive shaft
Weld diff
Used slicks
Line locker
Stock suspension
Strip EVERYTHING out you don't need for the race.
Obviously then big turbo, fuel system etc.
If you can buy right, a 10sec run for 10k is very doable...
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
