if your serious... and that's a big if.
Your best chance at a good time without alot of seat time or skills is...
You need a drag based auto.... think used c6 or 2 speed glide that has been built for drag with trans brake.
Bellhousing
Converter
Shifter
Drive shaft
Weld diff
Used slicks
Line locker
Stock suspension
Strip EVERYTHING out you don't need for the race.
Obviously then big turbo, fuel system etc.
If you can buy right, a 10sec run for 10k is very doable...
TBH thread is a bit of a joke mate...but it is interesting none the less...
I have spoken to a few guys at the strip about benefits of transbrakes and such, pricey buggers, that is 5k worth of box and brake, how much would you get one s/h for you think.. I was leaning towards an auto anyway...maybe I will ditch my manual box and build a drag car :P
how much power would be needed with all that though you think? 350,400kw should be enough ...which means a T67 could do it...
Good point XRATED with drag built auto transbraked. The cost alone for a auto would be 5k wouldn't it? That's only reason I didn't list a auto. But it's probably a must if you could get onto a decent cheap 2nd hand one
you can get reasonably well built glides with bell housing, flex plate and converter from the vl girls under 4k....
everyone underestimates how hard it is to get a powerful manual skyline off the line cleanly for good times at that power level. you could spend 2 or 3 drag days trying to get to where you could get in 2 or 3 runs with an auto and slicks.
for a one shot wonder.... I recon i could get a stock 25 with a stock turbo (with a couple of big external waste gates) in a well set up 33 to run a 10 sec pass. :yes:
around 370-380rwkw, manual, but slicks, drag radials just break shit, youd lose 40rwkw through a auto, so a T67 woudn't
do it auto
Auto youd do it first pass, manual would take at least a few meetings to dial it in no doubt..
cheers
darren
Well having 350, 400rwkws on a dyno machine is very different to actually been able to use them effectively for better speed and time. A power plant is only a thrid of all the necessary work required.
Chatting with people whom actually run 10s in drag days, there is no fluke in it, every thing from engine to drive tran to wheels, and weight has been worked on for the best possibly time.
That Yellow supra in my footage has 1000HP and he run 10.3s with huge cross ply tires. That car has been stripped with only whats required, work done from engine to wheel, it has taken the guy over 3 years to build and with minor configurations done for better results every time it goes to drags.
Its easy enough to say whom ever have done 10s and its easy and every one should be able to do it by bolting on what ever turbo to it. When comes to the drags with 350~400rwkws car, it is only a tinny step towards 10sec.
Artz take my billet T67 that actually made 400rwkws install it and drag it. See for your self what time you can get out of it.
thats exactly the turbo I'm thinking of using stao...that turbo with a rb30 bottom end would be killer..
but firstly I know it wont work atm because my car isnt setup..so power isnt my issue..
What I am looking at is how to setup for grip and ease of the line with the power I currently have...even considering just a built skyline auto as they are relatively inexpensive and fairly tough
4 wheel drive would be a huge advantage.
Mine isn't griping in 1st gear even with M/T, and after few tries it starts to launch on a single wheel. how ever once goes into 2nd it grips fine.
I'm trailing the VNT SS2 now so that billet T67 is just collecting dust, it should drop straight into your turbine housing try it and see what happens. Trent is organising a private drag day at Heathcote when they come back from Chile so we can go there for unlimited runs through the day.
Like everything its a compromise... weighs a lot more. still get plenty of wheel spin if you leave too hard and you'll bog harder if you leave soft. allows traction with harder suspension though.
M/T's will be more sensitive to tyre pressure. and you'll only really get the best out of them with plenty of weight transfer, with the right camber an toe settings under squat. not to mention a better diff arrangement....
it's all about how far you want to compromise the car away from street toward drag.
Like do you actually step it onto preset rev limiter by launch control and give full throttle on launch? Or give gradual throttle to allow torque building up gradually before step in full throttle. its not moving very far on first gear at moment.
You can't just use full throttle in first gear in a RWD with big power.
You need to balance throttle and clutch to get it off the line.
If you want it off the line, abuse the clutch.
are you talking about a 2 step rev limit or launch control? Best to speak with Trent about it.
If Trent has set up a clutch switch, I'd say he has set up launch control with some ign retard to build some boost on a lower rev limit... if that is the case, I'd be standing on it on the line, feed the clutch in and roll off the throttle if you find your blazing the tires to soon.
It really depends of the suspension, power delivery, track, tires, pressures, car weight, clutch, air temp etc....
At moment its seems to be just a 2 step rev limiter that sits on 6000RPMs when clutch is in. He's going to hook up the launch control with ign retard possibly Thursday and trying to launch at 10psi.
f**k the radials of for a start..lol, i can see you forever chasing you ass with those things..and breaking shit..
i'll take a 2WD skyline with slicks any day of the week over a GTR, i think it is much easier to get them to e.t
and hook up with a laggy turbo
cheers
darren
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
