r32 cooler kit $250
z32 with modified plug housing so an rb afm plugs straight into it with apexi pod $200
hiacas lock bar off r32 $50
gk tech s13/14/15 r32/33 rear camber arms only done 2 track days like new $150
r32 front calipers and discs with new qfm pads $300 (over $100 in pads)
r32 front strut brace $50
walbro gs450 in s15 bracket complete with sender $80
brand new window net with mounting kit $50
exedy twin plate clutch with throw out bearing to suit rb20/25 rb26 push type plenty of meat $800 (this is over 2k new was supporting 400rwkw no drama)
rb26 complete inlet manifold with modified water neck to suit s-chassie convo, nitto gaskets and dash fittings $400 (cost $550 just to get the thing polished)
r34 gtr rear drive shafts both pair freshly recoed $350 for both (note these are different then gtr r32/33)
5bolt drivers side rear drive shafts $50 each (i have 6)
s15 cluster with harness cluster is missing clear plastic cover $150
s15 black roof lining $50
s15 airbag kit jap spec steering wheel, clock spring passanger air bag with cover and air bag moudle $450
s15 climate control $50
s15 combo switch $50
all parts in castle hill 0407008651 please call or msg as im not on here often.
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
