  • Replies 40
Haha, maybe I'll buy it :P
I might have a rough idea of what it does. I know there's a light sensor on our R34 dash, on the demister panel on the passenger side. And maybe this auto switch can do what new cars can do nowadays, flick it on auto and your headlights will come on when the sensor thinks there's not enough light? lol
Not sure if I'll need extra bits for it, because I know that if the car didn't come with certain factory option, it will still have the plugs for it, but just hidden away.
Do the research, i reckon it would be more than just a plug and play application! IF it was it would be an epic find but i havent seen any R34 GTT's with them yet....
Not sure how to "research" lol, of the 4 years ownership of the R34, I've never seen that auto option before lol. And when I google R34 headlight auto switch, it's showing me results of actual headlights lol
Hahhaha ill tell you what the auto does :)
Exactly the same thing the Subarus do when on Auto.
Leave the Lights on Auto, Turn off the car and the lights turn off :)
Turn on the car and the Lights turn on :)
Ive been looking for one for my 34 for cheap, but all i find is over 100
That would still suit me! I forget them occasionally as i am mildly retarded :P
Don't know if that will even suit me lol
Since it's probably no good to me, here's a link for you guys :P
http://www.ebay.com.au/itm/Nissan-R34-Skyline-Indicator-Headlight-Auto-Control-Switch-/360406412572?pt=AU_Car_Parts_Accessories&hash=item53e9e56d1c&_uhb=1
3 stalks available :P
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
