Looking at some new front discs for a non-Brembo R32 GT-R as the oldies are starting to squeal constantly and RDA seem to be the cheapest decent discs around for a decent price. What i'd like to know is if there is going to be a big enough difference in performance between their plain discs and their basic slotted drilled discs to justify spending around twice the price? It's only due to still having the original nissan calipers that we're looking for a cheap 'band-aid' solution to last a couple of months.
https://www.sau.com.au/forums/topic/425219-worth-the-price-hike/
seems you need to decide if you want cheap band-aid fix or something decent...
have been told the RDA dimple ones are a good way to go.
Yeah, not got the funds for better discs, but bigger brakes are already high on the list of needs so it's only going to be temporary hopefully. I suppose everyone here goes GSLRallysport for their RDA+QFM setups? Any one maybe in Sydney or Newcastle or in between?
Edited by K4L4M1TY
Plain discs (Not slotted, drilled or dimpled) work fine on road cars. So just get some of them and save your money.
Just rang GSL Rallysport and Brakes direct, both same prices and said plain discs are actually more than the slotted ones. Shipping will be a bit more from GSL probably but i'd rather go with an SAU advertised dealer than anyone else and especially over the guy on Ebay with some hilarious feedback. I think i'll ring GSL back and see what they can do for postage on them, cheers for the advice so far.
Slotted rotors work, I reckon the pad bite is unreal.
However no, I don't appreciate the price difference.
I buy standard rotors for 70-90 bucks a pair and send them to a CNC machinist friend who slots all my new rotors for a quick cash job. I generally end up at least 50 bucks and sometimes well over 100 bucks ahead of buying them from RDA/DBA etc
All that needs to happen is to set out an inner radius of pad area, an outer, and to make some arcs any slight radius rouhgly 6 times over the rotor. Then flip over... An easy task for any CNC machinist who knows what they're doing with a bullnose bit.
Alternatively, I reckon the Sumitomo calipers are more than enough for a Skyline... Just a decent set of pads and standard rotors should do.
if you honestly want a cheap band-aid fix for only a few months, try ebay rotors.... mine havent fallen apart yet :ph34r:
Was going to until I read some guy actually got a used machined disc in his set which put me off instantly, like how bad do you have to be. Rang GSL Rallysport back and ordered the RDA front discs and a set of the QFM HPX pads. Told him I found him through SAU too which he seem pleased to hear. :3some:
Greg at GSL said RDA had updated their range and they were some dark anodised style dimpled discs so i'm keen to see how they look aswell. All I can say is thanks for the help guys and a big thanks to Greg at GSL for being very helpful over the phone and organising it all promptly, cheers mate. :action-smiley-069:
Why have you got big brake upgrade high on your list?
Do you take your car on the track a lot?
The stock brakes are highly effective for quite a while if you upgrade the pads and rotors before you need to go spendkng thousands on bigger brakes
With a few simple mods the car can be pushed easily to 350kw, with internals its 400, but yes the car will see plenty of track time once it is reliable enough not to break parts. The pads arrived on Friday, discs today. I really hope they get rid of the soft, spongey, very un-nerving feeling the car has had since purchase..
Look at adjusting the brake peddle up.
Similar problem on my 32GTR (ABS).
I have replaced everything with new to get rid of this - Discs, pads, callipers, braided lines, BMC upgrade, Booster. Bled 5 times with new Motul 600bf (by 3 different JDM Import shops).
About to replace new Ultimate pads with new Project MU HC+ pads (not cheap) any of this.
Note: ABS DOES NEED BLEEDING.
I'm fairly certain now that I need to adjust peddle to where I feel comfortable/confident.
I should have done this first :/ (plus it should have been suggested by said "experts").
Edited by Sinista32
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
