  • Replies 47
worth the risk? i think not!, the cops wouldnt know the difference if you had a gutted cat though!, but the exaust smells like the proverbial without a cat! and does it really make that much difference?
So bascially: if the cops see you have no cat (provided they know what they are looking for), you are in the deep end, and I think they can ether yellow you, or report you to the epa. If they see a cat (even hollowerd out), then you should be fine.
https://www.sau.com.au/forums/topic/42526-cat/#findComment-868839
why do you like having no cat?
because u like having flames out ur exhaust?
do you think it's really giving you heaps more power?
or you're being stingy and don't want to fork out for a high flow cat?
you know the exhaust fumes are heaps more toxic and poisonous without a cat, the smell stays in ur clothes, makes u sick and gives u headaches.
https://www.sau.com.au/forums/topic/42526-cat/#findComment-869648
tdawg if i see your car on a cruise I will write down your plate and get as much photo evidence as possible, and report you, there is nothing more im sure the epa would like than to make an example of someone
think about the environment for a change then the 1 or 2% power increase you get tool !
https://www.sau.com.au/forums/topic/42526-cat/#findComment-869945
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
