-Straight pipes, twin 3". $80
-Jap brand 3" cannon, has mount for R32 which it came off of. $50
-Drivers side fixed low rail (has adjustments though) Came off a Bride Stradia in a R32, but will fit other cars. $100
-Garage 7 R31 Roll Centre Adjustors 30mm, brand new still, comes with high tensile bolts. $150
-RB20DET gearbox, 2nd gear syncro not the best on hard shifts, other than that the gearbox is fine. 134,XXXks on the box always used Redline gearbox oil. Only pulled out a month ago, make an offer
-Nismo RB20 short shifter. $100
-RB25 "Quick Shifter" 25% less gear throw whereas a normal short shifter is only 10%, very notable difference, comes with solid shifter bush. $100
-Kicker sub and amp in a proper kicker ported box, plus full Kicker wiring kit. $200.
-Kenwood W3011 12" Sub in box $100
-R32 Clutch slave used but in good working order $20
The following stuff is BRAND NEW, unused:
-Turbosmart Dual stage boost controller $150
-Turbosmart fuel cut defender 2 $100
-Viper 5901 Alarm, has remote start and anyone that knows Python/Viper Alarms knows that these are quality units $400
-Saas gauges, black face with white dials X2 water temp and 1 Volt gauges $50 each
-Heap of redline oils, auto/manual trans and motor oil $80 a bottle
-Random brand podfilter with heat shield, think it's a 4". $20
Taking offers on some of this stuff want to start clearing it. SMS/PM me for more info/pics
Swing me a PM/text for pictures 0431308647
Located in Mount Barker, South Australia.
Will post if paid for by you.
Bump, can't edit original post. Straight pipes sold
Also have some 17" tyres good for a few skids if anyone is interested chuck us an offer
Bump, short shifter and RCA's sold.
Can't believe the amount of people that have messaged me about the gearbox and no one has picked it up. Will take $200, someone come grab it
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
