Hi guys,
I'm new to the forum and have been searching around for an answer to my question. I've searched around but couldn't find the exact answer I was looking for.
I own a 32 gtr that has this kit installed on it, along with the z32 afm's (all on the car when I purchased it).
http://www.kudosmotorsports.com/catalog/trust-greddy-suction-kit-trustgreddy-airinx-nissan-skyline-r32-gtr-r33-gtr-r34-gtr-rb26dett-p-919.html
I was wanting to put the oem air box back on but I know the inlet on that is 65mm and the z32's are 80mm. The above kit ^ can suit the stock afm's, but this needs to be specified when purchasing. Would the kit that suits the oem afm's just have smaller intake pipes? For me to have a suction kit on the car but with the stock air box, would I need to sell the entire kit I have on the car and buy another one to suit the 65mm afms or is there a much easier option? I also know the nismo units are 65mm's, as I don't have the oem ones so would need to purchase some, but they are pretty expensive.
How much could I sell this kit for second hand?
The reason I may have to put the stock air box back on is for the car to get a roadworthy certificate, but I'm not 100% sure yet, just need to know what my options are when the time comes.
Thanks for your time, look forward to hearing responses.
https://www.sau.com.au/forums/topic/425281-greddy-suction-kit/
To clarify for you, you can run Z32 AFM's on your standard airbox although you will need to modify it to suit the larger size diameter of the Z32's.
By the "suction kit" I presume you mean both the replacement "Twin Turbo" pipe and the intake pipes for your filters as a whole. In the case of you fitting a standard airbox you definately need to get rid of the intake pipes and replace back with OEM as your airbox wont fit otherwise. I have seen the replacement Nismo twin turbo pipe fit with the larger Nismo Airbox on standard however cant comment weather your Greddy pipes will work with OEM box.
Thanks for the reply.
So your saying If I want to modify the standard airbox I can keep everything I have on the car right now (except for the pods), but, if I keep the airbox standard, I need to change both the intake pipes and the z32's to smaller units (65mm)? If I changed the intake pipes to smaller, can I still keep the greddy replacement twin turbo pipe? How much would this effect performance having the oem air box on with smaller afm's but then having the larger greddy twin turbo pipe? (if its possible to run it like that).
  • 1 month later...
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
