Just Bought A 32, Where Are Some Good But Reasonably Priced Workshops In The South East?
Just picked up a mates gtst for a pittance but it needs some serious attention mechanically
I used to take my GTR to RE customs but it looks like their phone is off, ill go by their after work to see if they're still open
Can someone recommend a good reliable but reasonably priced workshop in the south east i can get it towed to, cant trust the drive, rather spend on a tow than damage the hydraulic / power steering system and cooling system.
ive read on hear about sabbadin automotive being ok, would like other suggestions, will try speak to both these people after work today
thanks in advance
Rich
Edited by V-Spec
i live south east, i know chasers is good but ill go speak to OTR, Sabbadin and see what happened to RE customs
anyone know if RE is still around, all these shops are relatively close to each other
thanks for the quick replys and information!!
what shop would be the best to source second hand parts and install them?
I thought otr is a supplier?
Sabbadin is great!
Chasers would be my bet
They have a workshop...they do very cheap work. My turbo install was $280 including removal and replacement of broken exhaust manifold studs.
wait, birds, were you talking about Sabbadin or chasers or your original recommendation of OTR?
im a bit giddy about the car, i re-read the thread and i think you mean OTR
Thanks!
Edited by V-Spec
RE customs moved shop to a few factories down. my run-ins with them over the last 12 months have not been positive.
+1 for sabbadin, also Ace Dyno + workshop in clayton is round that area. Anthony is a good guy.
Was talking about OTR...nice and helpful guys. Sabbadin also do great work, I don't imagine them being as cheap as OTR though.
Brad from RE now works at RTR in Dandenong. I had them do a wheel bearing and a service and we had the Member Renewal / Dyno Day there. I'll be going back for sure.
yeh sabbadin arent the cheapest, but you definitely pay for a good job done. hes worked on all of my cars.
Ive taken birds advice and organized things with OTR Rich
nice! i never knew they did service work, definitely wouldve gone to them if I knew
RTR is great, great mechanics there, but are a little expensive.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
