Will try and post up some vids later. The "win" vid is pretty unexciting if I'm honest.
However the rest of my weekend sure was a lot more interesting in a way than my first day.
Sunday morning we had our full audit scrutiny done - of which part was to test the kill switch. What I didn't know is that a kill switch cut-off in my car sends the car into limp mode.
This was only discovered as I headed out onto the track to take my position on pole for race 2. Unfortunately it meant I had to head into the pits and had a DNS for race 2. The fix for the limp mode is a simple plug into a PC and clear the fault so I was fixed 5 mins later but it was a simple lesson learnt on my first race weekend.
Upshot of this was it meant for the final race I started from the back of the grid. Conditions on Sunday were dry so the top GT cars had more speed on me regardless but none the less I was able to make my way from 20th all the way back up to 5th by the end of the 12 lap race. In reality I probably would have ended up in 5th even if I started 5th as the top cars are a good few secs / lap quicker than me at this stage.
But it was great fun coming through the field and was a nice learning experience including some pretty fun passes such as going between 2 cars down the main straight with only a few cm's space on each side.
Was good fun and I look forwards to the next one in Oct.
Here's the race win vid. Other than trying to go from hero to zero at turn 2 and dealing with lapped traffic at the end (yep I had lapped traffic in a 4 lap race) it's not all that exciting.
Still - here it is.
  • Like 1
  • 4 months later...
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
