Hi guys.
Fitted a Custom Split Dump pipe, full exhaust, high flow cat
Pod Filter (With bracket and plate to separate from engine bay)
Stainless Steel Turbo Snout
FMIC
and tried 3 different boost controllers.
My Car is overboosting something cronic. When I accellerate hard, the boost will try and hit 15psi+ (and boost cuts, retards, dumps fuel etc)
I have tried 3 different boost controllers, 2 being bleed valves, 1 being a apexi AVC-R.
We took the actuator hose off, and fed it 20psi from and air compressor, and it moved open and shut freely.
The car still overboosts.
Can anyone give me a hint etc on why its doing this?
A mechanic quoted me $500 for an actuator and wastgate for my stock turbo.
Then I have got to add labour onto this!!
Let me get this straight - wastegate actuator has been tested to be okay. I assume that you know you are getting 15psi+ because you have an aftermarket boost gauge.
1. Have you tried a mate's aftermarket boost solenoid? This might be an issue.
2. When you tried the AVC-R, did you fully set it up correctly i.e. aftermarket solenoid and pressure sensor, change hoses ans fittings, disconnect factory solenoid, ECU wiring, etc.?
Don't know if I can be much help, but you can PM me if you want to chat (I am in Townsville).
Good luck,
but your missing the point.
With a hose connected from the pressure side of the turbo, directly to the wastegate, it still overboosts, rather than going to 7psi (stock actuator setting)
And yes, I have a brand new aftermarket SplitFire guage.
have you checked when the actuator actually opens? youve fed it 20 psi and the arm moved freely so its obviously open at 20psi, but at what pressure does it actually crack open?
ok.. The actuator opens fully at 14psi.
This is about right, because it needs a little tension from the exhaust pressure trying to force it open while the engine is producing pressure..
This is how the car is -
0 - 5,000rpm = 9-10psi
5,000 - 5,700rpm = surges to 12-14psi, and boost cuts, dumps fuel, retards timing etc (factory ECU)
5,700 - 7,000rpm car goes back to 10psi, more power again
i reckon it's your split dump pipe to blame
that it isn't letting the wastegate flow enough
nah its not that, because my split dump pipe is awesome, and flows heaps, and can hold 10psi boost at 7,000.
I spoke to my mechanic and told him my findings. He said the actuator should be creeping open at 5psi.
Mine starts creeping at 14psi.
I thought it might have had extra tension because of engine pressure, but he said no.
Have you actually tried just running the hose straight from intake to the wastegate without having anything at all in it?
I would think that would be the first thing to try if you havent already.
Also you mechanic is wrong, boost pressure PLUS the exhaust pressure are both pushing to open the gate. So the compressor test is kinda void.
thats what I thought..
He said it should start creeping open at 5psi.. I am thinking, as soon as the engine creates pressure, its going to blow the wastegate open ... and blow all my boost with it..
This is fcuked, there is no - one in this stupid town that can give me a straight answer.
I hate mackay because its full of "I know it all but are wrong" rednecks.
Have you tried like i said, with just the line running straight from the intake to the gate?
I am going to get myself a slightly weaker actuator... something that opens at 10 psi, because this one opensat 14psi.
This should effectively drop my Boost by 4 PSI. That way if I wat more, I can use a bleed valve.
I don't know if this is going to solve the problem though.. .COuld create more.
Anyone actually had this problem before?
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
