hi all,
iv been around cars a lot and had a lot of cars, tho this is my first import, got a 89 bnr32, gtr,
specs follow as forged bottem end, slight head work, r33 gtr v-spec turbos ( how can I confirm they are?)
mines computer( yes im looking for a power fc) other then that its prity standed, the way I want it,
gose very well, 275s and wheel spins thru 2nd and 3rd,, told its roffly around 400rwhp,
I wana get it checked and tuned to make sure its running ok,, has about 13-14psi boost at the moment,
https://www.sau.com.au/forums/topic/425321-new-to-skylines-got-a-gtr/
welcome.
is it a factory ecu with mines sticker?
if so, get it changed soon.
and try not to give it too much.
Japanese tuners tune for 104octane from memory, so could do damage.
get you pfc, or haltech, vipec, wtc...
there are some good options out there for them now.
hope you enjoy your new ride, and the site.
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
