Hey Guys,
This is your invitation to attend the Sparco Academy - a one day motorsport event being held half way between Gold Coast and Brisbane.
We usually get a few SAU Members out to our days, but this one is pretty special so i figured it was worth a post!
Expect a full day of non-stop action out at the track, with training and events designed to hone your skills, followed by a "top 8" battle at the end of the day, with winners taking home a range of Sparco prizes.
We have Professional V8 Supercar Driver Steve Owen and Exedy Pro Drifter Levi Clarke available on the day for classroom sessions and even one-on-one training on track.
Anyone with a safe and well maintained car that is not silly-loud is eligable, groupings are based on driver skill and overall car power so the big boys can battle it out, while the beginners can practice!
Earlybird Pricing until the 26th is only $190.
After then it goes back to the normal price of $250.
This includes all classroom training, 4+ Sprint Sessions, Unlimited Skidpan, One-on-One drift training, cruise session and more...
$50 extra gets you one-on-one on track driver training with Steve Owen (V8 Supercar Driver)...
The one on one training alone would usually be $500+ minimum.
Facebook Link:
http://www.facebook.com/events/567407649948042/?fref=ts
Entry Forms / More Info :
http://www.hardtuned.net/sparcoacademy
400700_10151657760549365_1686424361_n.jp
Edited by loz-nscom
A few skylines entered so far.... would love to see some more 34's though!
We have over $500 worth of Sparco Prizes, so if you have a fast car, you might get a chance to take home stuff worth more than the entry!
Edited by loz-nscom
Silly loud = straight through exhausts...
if you have a hotdog & cannon with screamer... it is generally ok...
if it's a massively worked GTR with big cams and just a cannon... probably not...
this event is a one-off since locking in time with a V8 supercar driver can be hard, but we do hold hardtuned track days at the track every 6 months.
there are 40 spots left. Tomorrow is the last day for discounted entry however.
  • 3 weeks later...
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
