Hey all,
A while ago the RHS inner guard liner / splash guard clips fell out whilst I was driving and the liner rubbed against the tyre - which wore a nice hole it in.
Ive found a replacement but its from a series 1. So i'm wondering if there is a difference between the Series 1 and Series 2 guard liners / splash guards? and if they are a straight swap?
Anyone able to confirm if they will fit?
Cheers
Adam
Cheers for your reply mate. I actually didnt think to check for a part number on it LOL
Although I just had a quick squizz... where the tyre wore a hole in it, is right where the part number was. I've manged to get a few numbers off it - not sure if its a full part number or a partial though:
P/N : 3844 26U00
Thats the original off my R33 (Series 2) and the one I've found as a replacement is off a series 1 R33
Any ideas?
Cheers
Adam
Thanks for the reply H4x :)
I'm not sure if thats the part number or not, unfortunately when the guard fell down (whilst driving) the tire has worn a hole right where the part number is/was
Of the numbers I could see/make out, I got: 3844 26U00
Is there a different part number for the left / right sides?
Cheers
Adam
Cheers
Adam
S2:
RHS=63844-26U00-
LHS=63845-26U10-
S1:
RHS=63844-15U00-
LHS=63845-15U10-
As you can see they are different part numbers. Whats the difference between the two? I don't know. Just get one from a 96-97 coupe or sedan non GTR and check the part number matches.
Edited by H4x
Awesome, Thanks heaps everyone for your help - and thanks H4x for the confirmation and part numbers!
Indeed it is correct that they are not compatible and are different. Once I had the part numbers for both S1 and S2 I came across this post (here) which had these pictures in it, which shows the difference between S1 and S2 splash guards
Now im trying to find somewhere that I can get a replacement (Have been watching ebay/gumtree/for sale section of forum - but they are usually over east australia or from a S1)
I came across a website called amayama that sells them apparently? Anyone had any experience with them? (Link Here)
Cheers
Adam
I converted a Series I.5 to a Series II and the liners are different due to the different shape of the front bar.
I have purchased them from Just Jap and Nussan Aus for about $70 each because you can never find them second hand when you need them.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
