ok guys I kept this package for a mate as it felt strong and he has already paid me for it BUT i need it out the way as im struggling for room, he is stuck working up in QLD for the next 3-4 weeks and said i can sell and he will get the next package :P so not too fussed if it doesnt sell but be good to have it out the way a.s.a.p (before i get another wreck)
Complete series 1 RB25det engine package,
Engine with hot and cold sides all acc 140,000km's compression 155-160 across all cylinders
Full engine loom
ECU
AFM
Sports filter
Red jacket coil packs
Xtreme heavy duty clutch
only thing i took off was the engine mounts and brackets for my project :P
$1500
located northern suburbs of Adelaide do have a crane here so bring your ute or trailer :P
https://www.sau.com.au/forums/topic/425376-rb25det-engine-package-for-sale/
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
