Hi Guys,
Doing up a list of things to change ona friends r34gtt and we would like to replace the stock boost guadge with something that reads in PSI.
Is there a direct replacement item, using the stock sensors? i read somewhere the nismo one should be, but i could confirm this / or find a PSI one.
s there much work involved in fitting an aftermarket gauge, what size is the mount?
i wouldn't mind fitting up a turbosmart one, http://www.turbosmart.com.au/product/boost-gauge
Is there a tutorial on removing the triple gauge mount? i did find one on this site, but all the picture links were broken :(
cheers!
Christian.
The triple gauge mount is a 2 second job, just pop the a/c vents out with a flatblade and then undo the 2 phillips head screws!
Why do you need a PSI one? Actually WHY do you need one at all? Depending on which state you are in it is possible to create a defect for yourself by having a boost gauge on the dash!
The Nismo item is a different colour and generally expensive! I purchased 3 stepper motor gauges to replace the stock ones and it cost $170 all up i think!
And i deleted the boost gauge :P
As the Geeteetee gury says, take a flatblade and pop it out very easy to do
I was thinking of changing mine as well.
I read in another topic that the stock ones arent accurate when it comes to the temperatures?
But I guess if your car is stock there isn't any need to change them.
Cheers.
Going to be installing an aftermarket actuator and changing the boost level to around 10-11 Psi. Using the stock Gauge I would have NFI what level its at, as its super vague.
If the car already has a boost gauge i cant see why they would defect you for have a different type of boost guage. I think they only care if its obstructing your vision, and since its the stock location it shouldn't change anything.
Sounds easy enough to remove, will give it a shot.
Edited by Unkn0wn
Just use the stock on and get a rough idea.... The factory one is 1 bar or 14.7 psi etc, should be easy enough to tell where 11-12psi is.... Plus if you set the boost controller up right you shouldn't need to watch it....
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
