I have a small coolant leak I wish to fix before it becomes a major one. The join that slips inside the top radiator hose which the hose clamps to has become rusty and has deteriorated away. It looks to be part of the factory inlet plenum. Just wondering if these are repairable/replacable or if its easiest/cheapest to replace the plenum. Search found me nothing relavent.
Thanks
Edited by FordyR31
https://www.sau.com.au/forums/topic/425438-top-radiator-hose-connection-rusted/
Is it possible to weld to the plenum? Have thought, if you can, about grinding the rusted pipe off and welding a new pipe on to fit the hose to. Dont really fancy jamming a pipe in. Thanks for the reply.
Edited by FordyR31
yes its easy to cut off the rusted section and get a new bit welded on(i had it done to a 20 manifold)
needs to have a bead welded on the outside edge of the replacement as per factory
any good ally fabricator can do this and for reasonable $$$
dont bother buying another (possiblyrusty) manifold
  • 4 weeks later...
  • 4 months later...
Found this, no one had mentioned it, not sure if many people know about it. I will try to fit it up tomorrow and see how well it works.
http://www.uniqueautosports.com.au/Parts-Shop/uas-chrome-molly-upper-radiator-outlet-intake-manifold-76.aspx
    • Definitely didn't put a N/A cluster in instead? The speed sensor (location) is different in both cars.... I think. This will obviously stuff things up.
    • Nah not the throwout bearing, it's something internal. I already replaced the throwout bearing. Mechanic misdiagnosed my car and thought it was a spigot bearing, went to another bloke who said it was an input shaft bearing. (I replaced everything when I pulled out the gearbox but didn't open up the gearbox.   In this video at timestamp 6:05 : Mine has the same sound  min
    • It is definitely to space it out and away for clearance during compression, and possibly for spring clearance to upper arm. That latter would only be true for springs that are same-ish diameter to stockers, and so that probably doesn't apply to Teins or most other coilovers.
    • Yeah, a mechanic who knows these cars told me even if I get a brand new gearbox the noise will return but will be less noticeable. I've heard someone also they this noise came back after 3,000km on a new or reconditioned gearbox. It is pretty f**king annoying though just hearing groaning most of the time lol. I wonder if an aftermarket input shaft bearing would fix the problem or how they are built.
    • All RB gearbags, especially the big turbo box, have rollover noise. Mine certainly does. Always has. Sometimes is worse than others - no particular idea why, although it is probably temperature related. I have smurf jizz in mine and have had to have it in there from the first day the box went into teh car. It simply would not select gears with the engine on, on day one, with normal oil in there. And so, the blue stuff has probably ruined almost everything synchro related in the box. But it has taken 12 or 13 years to get to the point where I simply must replace the box. It has become increasingly baulky of late, which might be symptomatic of the way I've been driving it, as much as anything. I shall have to make some corrections when teh new box goes in. Input shaft bearing noise will decrease with clutch pedal pressed because the drive is removed. But yes, more often than not noises that work like that are associated with the throwout. It won't matter either way, new box will mean this one can be relegated to the parts pile.
