Hi guy's im new to this site, I have had a search but can't really find an answer to my problem.
So I got myself an r33 series 1 sedan, manual turbo.
I got it with a missfire on boost.
I have fitted new spitfire coil packs and tried different igniter and cas.
I have even replaced the cas plug as the wiring at the plug were exposed.
I took it into a tuner as the miss was still present, they checked over everything and said there is a earth missing at the rear of the intake.
I started stripping back the wiring to find the wire but thought I would check on another series 1 and see which direcrion the wire comes from.
I only checked 1 other car and it did not have the earth there either but series 2 do.
Mods are 550cc injectors, z32 afm, hypergear atr43, front mout and turbo back exhaust.
Was ran by a dr drift remap but I have fitted a brand new power fc due to a change in tuners.
The tuner told me he had the exact same miss with this earth missing but do series 1 have it?
what? so if the tuner knows what earth is missing why can't they just fix it? Normally the head f**k with issues is finding them, so what's the problem here?
Edited by superben
It has a miss/popping on boost.
I have replaced the coilpacks and tried a good cas and igniter.
All with no change to this issue.
Basically from 4500rpm on it misses but feels strange as soon as it starts making boost 3400ish rpm.
Strange as in it feels like it has more pull before it starts to make boost like it is pulling a ton of timing.
Im new to skylines so this issue has me scratching my head.
Does anyone have a series 1 in the west suburbs of melb that I could look at?
Is it a copper earth strap that gets bolted onto the intake manifold heat shield?
Hey, im interested in this too being an s1 owner.
I'm not sure about an intake manifold heat shield though, pics??
Joshman, i bought my car about a year ago and it already had an earthing kit on there so keep us informed please, :yes:
Nah I got it cheap because it had this issue and I thought it would be an easy fix haha.
It has bcpr7es in it which are factory gaped to .8mm.
The problem started since the intake manifold was removed and refitted so I will rip the intake off again this weekend to make sure it is sealed.
The vacuum was good but it has gone a bit crap lately.
Was 20inhg now its around 12-15inhg.
So you bought it with an existing issue that started once the inlet manifold was removed, and rather than check that straight away you create a vague thread about the issue.... Seriously dude, why start the thread, check the f**king inlet manifold like you thought was the problem all along.
I started the thread to find out if this earth at the rear of the intake manifold should be there, which from what I have seen is only on series 2.
If vacuum is good and you can't find a leak would yiu remove the intake manifold on an rb25?
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
