I am about to wire in a solenoid for my rb25, the factory wiring has been removed/shortened/missing.
I have found the factory output wire on the ecu connector but need +12V Ign.
Am I able to use either pin 49/59 as they are switched from eccs relay for the +12V or am I better of running a wire from the Ignition?
Why not look at the original wiring diagram?
As above, wire the mac valve to the original solenoid wiring
got the diagrams and looked over them that's not the issue
who ever did the engine conversion originally, removed half the pins from the engine loom.
I've got the wire on the ecu for the solenoid now I just need +12V. just wanted to keep it neat by using a +12v from ecu
But that's the point. Find out, from the original wiring diagrams, where the factory sourced their 12V from, and do the same as that. They won't have done whatever they did for a bad reason. They would have done it for a good reason. If you source it from the ECU you might introduce some nasty noise into the ECU (from the valve square waving on and off) or you might draw more current than it can handle on that line or any number of other foreseeable (or not foreseeable) possible bad things.
Follow the factory's lead, avoid those possible problems.
  • 5 months later...
Just another question does the MAC solenoid have an outputing voltage or its and inputing voltage. Im asking this because if i sourced the 12V IGN source from the factory solenoid. Where does the second wire go analog/ digital input or ???
The solenoid doesn't care how it is switched. You could either give it permanent 12V on one side and switch it on the earth side, or give it permanent earth on one side and switch 12V onto it from the other.
BUUUUUT...... What really matters is how the ECU wants to switch it. And from what your first post says (assuming you're correct), the ECU will switch the earth side of the solenoid to earth. So the second wire from the MAC valve just connects to the boost control pin on the ECU.
ok i wasnt understanding how it was completing the circuit without the ground. So its connected by 12v then the second wire goes to the ecu boost controll pin. How is the ECU controlling the solenoid, is it applying varied voltage to the solenoid.
nah this is a different case i have stock wiring. Went to a local meet and was told the same to use stock wiring where the old one was located so thats good if said more than once. Just didnt want to start another thread. Not sure if using thw stock will support the boost by gear functions but for now im happy will just wire it on the stock solenoid
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
