SERIES 1 PARTS
All my aftermarket parts are listed separately
Rb25det s2 motor
New genuine gaskets throughout the motor
New silicone hoses
New timing belt
Adjustable timing gear exhaust side
Painted covers
Everything was inspected sump was pulled off etc
Great compression across the board
Doesn't come with turbo but can provide for extra
$1200
R33 s1 headlights great condition
Has one broken clip for the grill
Chrome backing very rare
$250 pair
r33 gtst rear 5 stud conversion
hubs
rotors
calipers etc
$220
R33 complete boot trim
$70
r33 gtst front hubs,slotted vented rotors and brakes good for 5 stud
$220
r33 gtst drive shafts
great condition
$30ea
Rear reo
$40
r33 rear cradle just the cradle
$20
Radiator support great condition
$50
r33 gtst brake master complete non abs
great condition
$30
r33 engine crossmember perfect for rb conversions
$50
R33 power steer rack
Great condition
$30
r33 front sway bar
$20
R33 series 1 engine loom
Good condition
$150
R33 series 1 ecu
$70
R33 gtst gearbox $1100
Complete manual conversion $1450
r33 series 1 behind the dash aircon stuff
make a offer
r33 series 1 window trims from door and car the one that always fade
make a offer
r33 overflow bottle
$10
R33 gtst ignition barrel and locks with key
Good condition
$130
R33 gtst side mirrors
$20 each
R33 s1 drivers window switch
Good condition
$70
r33 passenger side gaurd with blinker
maroon and white
$20
R33 drivers side Gaurd with blinker
White
$20
R33 series 1 bonnet
White and silver
$120
Series 1 front reo
$60
R33 Gtr look alike front bar
Needs slight repair
$80
R33 series 1 dash
$30
R33 series 1 a
Manual diff 4.11
$140
R33 gtst centre console
Good condition
$20
R33 series 1 radiator
$50
R33 doors bare
good condition
$20 each
R33 gtst tail lights
Great condition
$20 each
R33 glovebox
$20
R33 boot with aftermarket wing/spoiler looks similiar to standard one lights up skyline
$20
R33 boot with o wing but holes
White
$20
R33 handbrake with full handbrake cable to hubs
$30
R33 passenger window reg motor
$20
R33 drivers window reg and motor
$40
R33 passenger window switch
$20
R33 bonnet latch and cable
$30
R33 bonnet latch bracket
$20
r33 boot and fuel flap latch assembly
$20
r33 air con unit/display
$20
R33 rear bar maroon, silver and white
$30
R33 complete air con set up with everything!
condenser
compressor
dryer
lines etc
$130
R33 rear seats
$30
SERIES 2 PARTS
R33 series 2 dash complete in good condition
$80
R33 series 2 manual diff
$140
R33 genuine gtr grill
White bit rough needs to be fixed up
$40
R33 series 2 headlight
One broken clip for grill
$70
R33 s1 manual complete rear subframe
$390
Bare rear subframe
$20
hubs
rotors
calipers etc
$220
r33 gtst front hubs, rotors and calipers
$220
r33 series 2 gtst drive shafts
great condition
$35
r33 gtst series 2 brake master complete abs
great condition
$50
R33 gtst gearbox
$1100
R33 clutch master cylinder
$60
$50
R33 series 2 power steer rack
Great condition
$30
r33 front sway bar
$20
r33 series 2 behind the dash aircon stuff
make a offer
r33 series 2 window trims from door and car the one that always fade
make a 0ffer
r33 overflow bottle
$15
R33 washer bottle
$30
R33 standard shocks and springs
$40
r33 gtst series 2 front seats
Great condition drivers have minor tear
$50
r33 series 2 rear bar silver
$40
R33 gtst series 2 ignition barrel and locks with key
Good condition
$130
R33 gtst series 2 side mirror passenger silver
$30
Silver
$30
R33 gtst series 2 centre console
Good condition
$20
R33 series 2 door passenger
good condition
$20
Great condition
$30 each
R33 glovebox
$20
$50
R33 pasenger window reg motor
$35
R33 drivers side window reg and motor
$40
$20
$50
$40
$30
r33 series 2 air con unit/display
$30
R33 series 2 steering wheel with air bag
Make a offer
R33 series 2 complete air con set up with everything!
$150
i have all the interior plastics etc
So much more just can't think text me or pm me if you need anything
Gold Coast can post
0487924497
Hi mate,
Not sure if I missed it as I'm reading the thread on phone, but do you have the quarter glass for sale from the lhs? Had to break mine when the car locked itself with the keys in the ignition at a service station 1000odd kms from home...
Thanks
Jamie
Sorry mate, I missed your reply. So do you mean you'd take $50 plus post or $100 plus post?
Are the quarter windows on yours tinted or clear and how are the rubber surrounds?
Cheers
Jamie
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
