Howdy,
Up for sale the following bits purchased with project car which are no longer required most bits are new and never used unless specified. Also have a heap of bits from R32 and R33 wreck so let me know if you need anything.
6 boost genuine steampipe exhaust manifold to suit RB25
BRAND NEW (manifold was built to suit RB25 in R32 - compact design - but will be prefect for any R32 or R33 with an RB25)
Work of art to Suit RBb25 head stud pattern
T3 flange
50mm v-band external wastegate flange
NEW never used
$1100 plus post these RRP $1400
YELLOW JACKETS coil pack set R33 Series 2 (no ignitor box) - YJ-RB2526-S2
Straight bolt in for RB25
NEW never used - they have been fitted but never fired up. pic is not of actual coilpacks as I didn't get a photo of the actual ones
$350 + post
Turbo Beanie
Keep the heat where it should be - suit T25-T3 small T4
NEW never used
$60 plus post
Nissan Skyline R32 Reat strut brace bar GTST GTR - Looks like a whiteline?
Used in good condition
$100 + post
Nissan Skyline R32 Front strut brace bar GTST GTR - Also Looks like a whiteline?
$100 + post
Front mount intercooler 600x300x76
Perfect for the front of any skyline
Finished in black in great condition looks like new, has been used.
$100 + post
R32 GTST Gearbox and tailshaft combo
Has redline oil, taken out of vehicle with 145xxxkms on clock
$500 pickup only will throw in heavy duty clutch for extra
$100
ID1000 injectors 1000cc top feed injectors with injector plugs - and brand new Billet fuel rail combo
Complete setup $1100 good for Pump fuel or E85 capable of 350rwkw with supporting mods
NEW never used
$600 for injectors + post
$150 Fuel rail with -8AN 90degree fittings + post
Pro Flow inline fuel filter also available pics up soon.
Drift Steering wheel deep dish blank horn button
BRAND New in the plastic
$80 + post
Oil Cooler with Relocation Kit and all braided lines and -AN fittings kit everything you need to make it work - even filter
Brand new unused, bolted up for trial fitement, will fit straight into an R33 or R32.
$450 for the lot
RB25 cam covers with -12AN fittings on breathers.
Fittings are with $100 alone!
$150 for both covers and fitings
RB25 Coilpack cover
$50 + post
Innovate Afr Wideband Air/fuel Ratio Gauge
Comes with everything you get inthe Box, offers dark face or
silver face option
NEW never used.
$200 for everything
RB25 R33 Silicon radiator hoses
Top and bottom hose
NEW never used
$20 + post
Oil Filter sandwich plate + all braided lines and -AN fittings.
Got your own core? Use this to plumb it up.
Has been used but in good condition
$80 + post
RB25 R33 engine mounts
Used good condition
$80 pair + post
Exhaust heat wrap roll
NEW never used
$50 for the roll enough to do manifold and dump pipe.
R33 AC compressor
Used and no longer required purchased with a spare engine.
$50 + post
R33 power steer pump
$30 + post
I also have a range of R33 and R32 bits so PM me if you need anything. Will post more items soon.
Located in Sydney Hills Area prefer pickup will post at buyers expense, all prices negotiable although please no
time wasters - time is precious!
  • Like 1
https://www.sau.com.au/forums/topic/425521-r33-r32-performance-parts-and-wreck/
But wait there's still more...
Surge Tank Setup with GENUINE BOSCH 044 700HP external pump complete mounting bracket ready to go.
BRAND NEW never used, fabricated from aluminium looks neat as - not ebay alloy. BYO hoses and your good to go with this one
$320 plus post ono
Cometic stainless steel gasket to suit RB25
New and never used
$50 posted
JJR steering wheel quick release
New and never used
$50 posted
Injector Loom to suit RB25
Great condition plugs are fresh as.
$40posted
GLOW SHIFT electronic Fuel PRESSURE gauge 52mm
New and never used comes with all senders and wiring
BLUE led - look awesome day and night
$75 posted
GLOW SHIFT electronic OIL TEMP gauge 52mm
BLUE led
$65 posted
GLOW SHIFT electronic OIL PRESSURE gauge 52mm
BLUE led
$65 posted
GLOW SHIFT electronic WATER TEMP gauge 52mm
BLUE led
$65 posted
$250
SILICON Radiator Hoses
NEW never used - $20 + post
$80
R33 clutch fan
Great Condition
$80 + post
R33 space saver spare wheel
Great Condition
$50 pickup only
RB25 forward facing plenum
Great Condition don't need as have a plazmaman
$300 plus post ono
R33 stock plenum and runners
Bare plenum no injectors of fuel rail, don't need as have a plazmaman
$50 plus post ono
R33 Series 2 stock coilpack loom/harness
Great condition
$50 posted
R33 radiator shroud
great condition no cracks or breaks, just needs a quick clean
$75 pickup
R33 Series 2 Door Trims
Front pair only in good condition
$60 pickup only
Blitz 52mm Boost Gauge
Great condition $55 posted
Bilet Fuel Rail with -6AN fittings as above
NEW Never used
$120 posted
R33 RB25 CAS crank angle sensor
Great working order removed from running vehicle.
$110 posted
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
