R32 GTS/ GTST / GTR Bolt in Safety 21 6 point cage $400 ono.
Goes around dash. has provisions for cross brace and harness bar in rear legs.
Has nuts and bolts but needs new base plates.
No longer needed as i went a weld in cage.
*Pick up only* or buyer to organise own freight.
R32 GTR Cluster $100 has 45, ooo ish km's on it
(currently in my track car, can get pick if needed)
R32 GTR Front Tailshaft (may fit 33, will not fit r34) $50
R32 GTR Transfer Case (will also fit r33 and r34 gtr) $150
R32/33/34 GTR Front turbo rubber intake pipe $20
R32/33/34 GTR Exhaust Manifold heat shield (only have one) $10
R32/33/34 GTR alloy engine mount (passenger side) $20
Z32 afm plug (used) with length of wire attached $10
R34 GTR Engine Undertray $50
R33 GTST intake pipe with bov return $20
R32 Bare dash pad, has bubble in usual spot on the pass side $20
Brad 0437 198 210
pm or sms / call me.
parts located in upwey vic, can also be picked up from dandenong during the day.
will send smaller items at buyers cost. prefer pick up on the larger items.
https://www.sau.com.au/forums/topic/425527-r323334-gtr-parts-cheap-melb/
GTRPSI - The car had back seats in with the cage when i got it, but it was a tight sqeeze, you wouldnt want to have passengers in the back.
Steve.b - Send me a pm / sms
Roy - Let me know wenever suits you mate, its in storage so i need a days notice.
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
