Hey guys new to the forum..
I am quite mechanically minded and have fitted an rb25det into a gu patrol.
I am running a stock as a rock rb25det skyline engine. Only difference is using the patrol top mount intercooler.
Everything seems to be running really well, doesn't overheat, boosts fine, runs 7 pound and everything seems responsive. BUT after a very short drive the turbo starts to glow and not under heavy load. And when I do heavy load it the turbo starts to get a brighter glow.. What do I do???.
https://www.sau.com.au/forums/topic/425529-my-rb25det-turbo-glowing-help/
There is no restriction full 3 inch straight through exhaust, has a 3 and a half inch brand new high flow cat literally done less than an hour running on.
Waste gate joins to the intake pipe as per standard rb25det.
And the top mount intercooler sealed with no leaks with no restrictions
hows your fuel economy? is unburnt fuel / still burning fuel going through the turbo? that motor will be working hard lugging around a fat patrol
Edited by StevenCJR31
Well couldn't tell you about economy as haven't run it long enough coz I don't wanna blow it..
I'm not 100% if there's unburnt fuel, normally there would be some smoke? Yes? But there is none, it does get some cracklling up when coming down gears.
A lot of people have done the conversion and had no problem with it carrying the wait.. Figured this was a problem someone might have had an issue with in a skyline.
if there was any smoke it MAY be burnt up in the cat ? for the turbo to glow like that there must be fuel burning in it, if that is the case then the stock turbo wont live a long life, from what ive read on here there hasnt been a lot of glowing turbo problem skylines~one or two with warped exhaust manifolds tho! would it be feasable for you to try a front mount ic to eleminate any possible restriction?
Yea can't fit a front mount without removing ac, and by glowing I mean turbo is red hot glowing... It shouldn't get that red from not boosting for heavy periods... In my opinion but I haven't worked With these motors before
Have you checked your timing? Could be that it is heaps retarded and blowing out the burning fuel through the turbo
Checked the timing and set it at 15 btdc With timing gun, and that turbo gets way to red hot.. If the crank was out would the car still run perfect but overfuel/ under fuel??
Sounds like It may be running lean, can be caused by a few things. For example when I bought my curent engine, there was a mix up with the plenums put on it and I got an NA one with NA injectors in it. Surprisingly the Motor still ran smooth (was surprised it ran at all) so took me ages to find what my lack of power was caused by. But anyway that caused my turbo to glow red with just moderate load. So morral to the story, check everything related to the fuelling system.
P.S. surprisingly I don't have 6 cracked pistons from the running lean from the balls injectors :)
Running lean it will generally run well (you make more power lean than rich, to a point). But it runs hot. I'd say that the fuel pump may be to blame, or possibly a blocked fuel filter.
Pull out the spark plugs. That will give you an idea on whether it's running lean
Has brand new vl turbo fuel pump, brand new fuel filter.. Everything runs really well when it's timed about 25btdc, but the turbo glows just not as quick.. Someone said it may be the reg letting through too much fuel? That's why I thought increasing the timing is helping it burn off but still not enough to keep the turbo cool. Thinking maybe aftermarket fuel reg. but I have a mate bringing a wide band over tomorrow before I buy anything so il know for sure..
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
