First post, Hi all;
Due to medical stuff I may only have so many years of vision left. When your eyes go a bit, your hearing picks up.
Time for a 'fun car' while I still can!!
My DC5, at any speed above 70 is like road noise gone to hell. I dont mind the sound of a nice engine, or exhaust, but road noise kills.
So, Supra's are on the list, but I hate the interior, dont mind the 300ZX; but prefer the skyline!
I want a project car, and will live with the DC5 for another 6 months while i 'work on it'.
After reading an article about the suspension setup, and the bushes vs none between the R33 and the R32 rear ends, is the R32 noticibly louder on the road?
I'm hoping not, because I prefer the R32 shape, I think i'd buy a shell and put a NEO in it as the project; but if the 33 is quieter, It wins hands down (and saves me the engine swap work).
Anyone have experience with both and care to comment?
Nice 2.75" exhaust with a couple of resonators to hear the engine but keep it freeway silent..... I can see it now :P
Advice is greatly appreciated :)
I know my tires are noisy for sure; but I notice if I put 3 people in the car it goes almost silent.
I say its a design flaw of the hatchback. Too much cabin room for sound to reverb. Filling it up with people helped.
the 32s are usually noisier than 33s (when fitted with the SAME exhaust system) as the 32s run a smaller 2 litre motor compared to the 33s 2.5 litre and the gtrs sound different again. . there is a few skyline nuts living in my area and i can usually pick what model it is by the sound of the exhaust before i see the car
bad luck bout the eyesight mate
Yeah, but it happens. Possible organ doner down the line; but for now its pretty scary. Spend like $6k every 3 months to keep my vision. But thats what you work for eh? to keep the things you love in life (like sight).
Ive found a completely stock R33 with less than 150,000k on it. Guys asking 7. Tempting....
My current car is worth about 9 though; i was hoping to be around the $5k mark so I feel better saving the comprehensive insurance money so I can pay my surgery.
Right now I have $1k a year in insurance for a non turbo honda :P
I guess I keep looking.... maybe hit up a few auctions.... my uncle is a dealer, so auctions are very cheap.
33 is a more refined drive, however I think the biggest factor irrespective of the model will be the modifications done.
With big mufflers its possible to end up with a quieter than stock 3" system. Another big factor will be the fuel pump which is not an issue for most because their exhausts are louder than the pumps.
I think with enough dynamat, standard fuel pump setup and a well thought out exhaust either car will be suitable.
If your not familiar with skylines i'd avoid auctions. Honestly the best place to buy one of these things is off another forum member, they are more likely to have kept up with maintenance and used quality gear.
Sucks to hear about your eyes but like you said best to enjoy your vision while you can. Goodluck!
You dont konw how cheap a dealers only auction is though :P even if it needed a $4k engine swap, it'd come out cheaper.
Also looking at a 350GT, as it might be the more sensible buy, but once again, $1k a year insurance which could go toward other things.....
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
