Yup - rear toe gives you stability. Keep it positive (pointing in)
FWD guys tend to use a bit of negative toe at the rear to dial out some of the inherent understeer and get the shopping trolleys to turn in properly. I had lots of sideways fun when I had a bent and cracked LH rear trailing arm. Under braking it gave about 6mm negative toe on the left hand side making for lots of sideways action coming into right hand corners. Lucky it was on gravel
  • Replies 41
Rather than focus too hard on the static rear toe figure, can you enlighten us what sort of toe change it goes through from full bump to full droop?
Getting on top of that is what would make the conversion worthwhile IMO.
    • I figured out what’s wrong. It’s something to do with the high beam wire short circuiting. When I measure the continuity with a multimeter on the headlight socket connector it gives me a continuous beeping noise when I put it on the ground socket and also on the high beam socket.  On the passenger side of the car (working side), it’s only beeping when the probe is on the ground socket. Which makes sense.  So that means it has something to do with the high beam power supply for the drivers side. How do I trace that? Is it the turn signal lever malfunctioning? The one that also controls the high beam and low beams.
    • Hey lads just finished tidying up a gtr a bought. Originally from Sydney now living in New Zealand
    • Hi Guys, Looking for this piece if anyone can help out.   https://tfaspeed.com/products/nissan-skyline-r33-gtr-rear-trunk-finsher-panel
    • How did you go with your problem? End up fixing it. Have a y34 aswell vq30det
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
