I bought an NM35, read the Info thread, and made notes. Also added a few tidbits I found.
UPDATE: Added more info from pages 1 to 9 of this thread
Engine
The V35 & M35 airboxes have the same part number. They are, Back of airbox 16526, front of airbox 16528, + filter required. The K&N filter that fits is 33-2031-2.
Air filter is Ryco A360 (same as all skylines, 350Z Z33 Series 1, some commodores and many other cars)
Air filter change interval: 20,000-30,000kms
Spark plugs NI22401-5M016…..they are also $24.15 each OR NI22401-AQ816 (or Denso Iridiums Part #IKH22) (or Denso IKH22)
Uses 5L of oil. Change interval is 5,000kms. Engine requires 4.8L to the H mark, 4.0L to the L mark
Oil spec: SJ, 0W-20 all the way to 15W-50 depending on usage
Oil filter is Ryco Z436 or Z445 : Nismo (Veruspeed) 15208-RN010 : K&N: HP-1008 : Amsoil Ea012
z445 - seal diameter 63mm, height - 65mm, seam diameter - 68mm, thread size - M20-x1.5-6Hmm
z436 - seal diameter 64mm, height - 66mm, seam diameter - 69.50mm, thread size - M20-x1.5-6Hmm
Oil filter is same as VQ35 and SR engines
Oil pressure sensor / switch: FAE SW9021 12555 ~$35 (same as 370Z, however, typically not listed as compatible but has correct thread and plug, and doesnt throw CEL)
Belts are the same as 350z; Air con - 4PK950, Power steering/fan/alternator - 6PK1180
Belts are 4PK945 or 4PK0950 and 6PK1180 (NOTE: the digit before the PK is the number of ribs on the belt, PK means automotive cross-section, and the number after the PK is the length in mm)
Standard turbo is a Garrett M24N and is a ball bearing unit with ceramic exhaust wheel
Factory boost is 12-12.8psi
AFM is same as T30 Xtrail
OBD2 plug is a small black panel at the lowest point of dash on the drivers side, to the left of the steering wheel. The plug is attached to the panel and it drops down when you open the release on the side. Xtool A30M ~$300 (and many other Xtool products) will read many M35 systems, including ECU, ABS, airbag, gearbox, 4WD. See https://www.xtooltech.com/english/FunctionQuery.html for function support details. etc
350z alternator is a direct replacement for the vq25det. 350z alternator is slightly larger, has slightly different mounts, the plug is different and the positive connection is in a different location. It would be very difficult or impossible to fit. NM35 part number is 23100-AM610 (MrStabby got it rebuilt for $260. Ebay from the US ~$350 delivered). The VQ35 starter sort of fits, it's larger and probably more powerful than the little VQ25 unit. The power lead is on a different angle and gets close to the hot side cooler pipe
Battery: Century NS40ZL (330 CCA) or NS40ZLX (premium, 390 CCA), NRMA/RAC 2384/2047/3053
Suspension and Brakes
Rear sway bar links (~$50) right 54668-EG03A (replaces 54618-AL510), left 54668-EG03B (replaces 54668-AL510). The newer parts appear stronger.
Front rotors and pads are the same as 350z touring/V35 Skyline/current Maxima
Rear rotors and pads are the same as the 350z touring/V35 Skyline/X-trail
The rear pads & rotors for the 350z or v35 will not fit without modification
Rda do nice semi metallic brake pads (~$30 per end), MUCH better than standard, not dusty
Rda front; RDB1232SM (Listed as Maxima front pad)
Rda rear; RDB1509SM (Listed as X-Trail rear pad)
Shocks are KYB 350z premiums and at NZ$225 ea. they are a bargain
Pretty sure v35/g35 front strut bar will fit m35
Camber/toe kit is same as g35/350z
BRAKE MOD: The M35 ecu limits the throttle to 30% when the brake is applied and for approximately 3 seconds after its release. Cutting the brake signal to the ecu disables this but it will eventually throw a fault code unless you find some way to trick it. (connect it up temporarily when you don't need throttle.) Most just run a switch and tap the brake as they flick it, only needs to be done occasionally. The kick panel ecu is for the trans, the ecu is behind the glove box. Mod is to cut the pink/blue strip wire on the ECU.
Drivetrain
Gearbox is RE5R05A
Gearbox fluid: Nissan matic J (or Nissan matic S, or Nulon synthetic (compatible with nissan C/D/J/K, $16.60perL) or Valvoline synthetic (compatible with nissan D/J/K, $10perL))
Auto trans fluid change interval: 60,000kms
Diff oil change interval: 60,000kms
Diffs require 1.4L each, and factory weight is 80W-90.
Syncro = 50/50 split up to 40 kmp/h then it goes back to normal.
Snow = 50/50 split up to 40kmp/h but starts in 2nd gear and reduces boost.
“ATTESA E-TS system is normally 0:100, but can split up to 50:50. SYNC mode is constant 20:80, but can also do 50:50. SNOW mode appears to be 50:50, but hard to tell, but it does NOT start in 2nd gear. Im guessing that there is a boost limit. ATF 'D' is reccomended, 1.8L is required to fill the system.”
Action Dans auto service [[http://www.skylinesaustralia.com/forums/topic/424256-auto-service-questions/ (not Stagea)
Part Numbers
Xenon headlight globe: D2R type, Phillips 85126C1 std 4200K, about $75 each. The Xenon is the top bulb, the bottom bulb is a regular H4.
Oil temperature sender: 22630-44B20 (same as Navara so available locally ~$73)
Lid Weatherstrip (Rear Sunroof Rubber): 91246-AQ020 $77.00 + GST = $84.70
Duct Air (Power Duct add-on for standard M35 air box): 16555-AM604 $163.00 + GST = $179.30
Centre Cover (Front Axle Plastic Guard): 75881-AQ060 $84.00 + GST = $92.40
Passenger side cam cover gasket: 13270-AL612
Drivers side cam cover gasket: 13270-AQ800
Fuel Flap Snub Rubbers: 78837-AG000 (The little rubber buttons that hold the fuel flap flush with the rear quarter panel)
Fuel tank O-ring: 17342-01A00
Fuel filter strainer: 16400-4M405 (Hornsby Nissan price; $38.70 in 2015)
Rear wiper arm: 28781-AQ010 direct from Nissan for $55
Rear wiper blade assembly: AY003-H25AR
Cabin pollen filter: 27277-4M400 or Ryco RCA113P (but: There's also a Ryco with a C at the end of the p/n which designates it as an activated carbon/charcoal filter, this is the correct replacement for the factory one)
Upper radiator hose: 21501-AL5000 or Gates 22967 or Mackay CH4966
Lower radiator hose: 21503-CD000 or Gates 22968 or Mackay CH4962 or CH4960
Front brake pads: DB1485 or Project Mu F209
Front brake rotors: DBA954
Rear brake pads: DB1509 or Project Mu R209
Rear brake rotors: DBA574
KYB front shocks: NSF9420R + NSF9420L (right and left sides)
KYB rear shocks: 2 x NSF2069
Water pipe (~350mm long, scarificial anode of cooling system, so will corrode): 21021-AQ802 Price; $64.56 usd.
O-ring: 21049-AE000 Price; $1.10 usd.
Front indicator globe: T20 21W
Starter Motor: 23300-AL600 ($375 @ synergymotorports, $330 ebay)
Starter Motor Brush kit: 23378-EN20A (also used in Australian model starters so readily available)
Turbo replacement gasket set: 14401-AQ826
Turbo to dump gasket: 14445-4P200
Turbo to dump gasket: 14415-4P200 (1) $41.61 each
Turbo intercooler piping outlet gasket: 14465-4P200 (1) $5.22
Oil return line gasket: 15196-73L00 (1) $2.97 each
Eye bolt gasket: 15189-01P00 (4) $3.48 each
Turbo drain washer: 11026-01M02 (4) $1.91 each
VQ25DET valve stem seals: 13207-84A00 (Looks like same as vq35, so there are aftermarket options available out of the US)
Belts: AY140-61175 and AY14N-4094E
Torque Convertor / front pump assembly auto trans seal: 31375-44X02 (Symptom, oil coming from between gearbox and transmission)
Front wheel bearing (AWD): NI-40210-AL800 (same as J32 maxima) Found to be incorrect. The correct CBC part number is NJ137KIT and should be available at any bearing shop.
Front hub assembly (AWD): NI-40202-24U00 (same as J32 maxima)
NM35 Radiator Filling
Thought I'd put this Radiator fill guide in here; seems like there's a fair bit of stress in doing this job, and that in turn scares people away from doing relatively simple jobs.
Stolen from V-Series forum; http://www.skylinesa...iunum-radiator/
Well done Nate, hopefully this de-mystifies the procedure a little and the post title will hopefully make it easy to find.
Yeah over heating can be a pain when u dont get all the air out, so get it done right the first time. Here is what you have to do for a correct V35/350GT/G35 coolant flush with no air bubbles (my post on g35driver)Well i got it, ended up doing this, which should be done from step 1:
  1. Wait till car is cooled down
  2. Jack up front or park on step incline
  3. remove rear bleed valve from heater hose
  4. remove rad drain plug with bucket under it
  5. remove rad cap
  6. remove and wash out overflow
ONCE DRAINED
  1. Put rad drain plug back in
  2. put bleed plug back in
  3. put over flow container back in
  4. get a long funnel or water bottle or non spill funnel and put tape about 1” from the tip of funnel or on the thread of the bottle until its thick enough to fit snug in the rad neck
  5. with car off fill the overflow to minimum.
  6. with car off slowly poor mixture into funnel wedged in rad with your premixed mixture (i used distilled and water wetter)
  7. Once you see it no longer draining from the funnel grab the lower rad hose and compress and let go a few times and see if anymore drains out, top it up if it all goes
  8. Start the car and slowly keep at least a bit of fluid so that the funnel is at no point completely empty
  9. As you see it no longer draining and staying where it is rev car to 1500-2000 for 30sec and then let idle. Repeat a few times
  10. As soon as you see fluid rise up the funnel and overflow container full turn car OFF
  11. Let rest of the fluid drain, if none is left very slowly poor more in until you cant fit any more in.
  12. You should put rad cap back on, start car again and turn fans on with A/C off and temp as high as it can go and fans on high
  13. Make sure you can feel hot air, that means coolant is circulating and passing hot air out, cold air = air bubble = slightly opening the bleed valve and letting air out until just water comes out.
  14. one you confirm hot air and/or no air from bleed valve turn car OFF
  15. If jacked up put it down and go for a drive, if all good then put under tray back on!
  16. Keep and eye on overflow tank for next week and make sure its at minimum
  • Like 5
  • Thanks 1
Well done..
I would clarify that that the 30% throttle restriction is not solely related to the brake signal. The primary limiting of the throttle (30% max) relates to being in first gear and under 2600rpm.
The brake mod removes an additional delay to throttle response.
Cheers
Andy
I have 100% throttle at launch, with the car in first... What are you on about Andy?
And you call your hybrid of a car a Stagea.... :P
I suspect that is more to do with other aftermarket electronic godies you have installed.
  • 3 weeks later...
The kit includes rear springs and adjustable shocks. The BC's are not harsh at all, well, that is until you fit poly bushes, swaybars and bracing...
I am still very happy with the BC's four years on.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
