  • 1 month later...
Hey all Anyone know what the part number for this bit of pipe that runs towards the back of the engine from the rad or if its an off the shelf part for that matter lol.Looks about 3 or 400mm long, the front of it in the red ring is abit stuffed
Thanks!
They are all a bit stuffed. They don't seem to leak though, no matter how bad they get. That pipe is designed to rust, sacrificial anode as part of the cooling system.
ah yep the thing is the front of it is rusting its starting to leak in the red ring end, got not much to clamp onto now lol
I have some s/h ones here that are quite useable, but get on Amayama and see if you can find the part, it may be cheap... Or not. :P
Bam. :woot:
Water pipe; 14053M
P/N; 21021AQ802
Price; $64.56 usd.
O-ring; 21049
P/N; 21049AE000
Price; $1.10 usd.
You're welcome.
The Russian version of epcdata has all the exploded diagrams, where the English version for whatever reason does not.
Eliminates all the guesswork.
All the prices are through Amayama, not regional Nissan dealers, so I'd suggest getting a few items to make the shipping worthwhile.
From Scotty's post in another thread;
M35 filter: 16400-4M405
Both look identical, and both have 0.1mm larger outlet holes than the stock one I removed.
I will suggest everyone replace the outlet Oring (P/N: 17049-4M400) when changing the filter,
Anyone have interior dimensions of either NM or PM35's?
I have seen them before for other Nissans - diagrams showing the whole car including interior and exterior dimensions.. No idea what manual/catalogue they would be from.
I had a mate translate some of the Stag owners manual. Engine oil change interval is 5000kms, not 10000, and it looks like the filter is every second change. Huge variation in oil viscosities is odd...Diff oil change interval is only 60,000kms, so i know what i'm doing on the weekend.
Going by thet table, it looks to me like the filter is every change (except for the diesel)... as it should be.
The oil they are going by there is the old Nissan semi-synthetic which would need a change every 5000kms.
Depending on the oil, you can actually do 10,000km oil changes, but you won't have much change out of $130-150.
  • 4 weeks later...
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
