Hey guys,
Does anyone have the part numbers for nm35 A/C belt and Alternator belt?
The writing has worn off mine so makes ordering difficult without pulling them off to measure.
Cheers!
Ha, I was looking at belts today myself.
Genuine numbers were AY140-61175 and AY14N-4094E
Starter Motor 23300-AL600 (expensive new and ex Japan)
Starter Motor Brush kit 23378-EN20A also used in Australian model starters so readily available.
I did my wiper blades recently. Main thing with rear is to make sure that when you trim it down, there is something to hold the 'rubber' in place and prevent it simply sliding off the end, as the wiper arm holds the entire spine of the blade .... if that makes sense.
reason I say this is because it took me two lots of blades to find one that didn't just slip right off the end :S
  On 22/07/2013 at 5:42 AM, ironpaw said:
Surely a r36 Passat is nicer in every aspect on comparison to a stock pm/nm35?
Apart from servicing costs and exploding DSGs that is...
And the fact they have tried to make a boring car cool and failed is also another reason to go stagea.
And when people ask you what you drive, R36 or not a passat is not a car you can tell them and be proud of it.
If you say stagea 90% of people dont know what they are. So your all sweet.
Edited by Howaitonaito
  • Like 1
some would say the same about our lunchboxes. Wpuld depend on individuals wants and needs.
  On 06/01/2014 at 8:50 PM, joshm35 said:
Im after front wheel bearing part number and if there are any cars that have same wheel bearing.
I have a few aftermarket front wheel bearings here from the US... Nissan ones are just too expensive.
yeah i just purchased one from ebay but usa seller said week later he is sold out. What would you sell me one for scptty. Pm me
  • 5 weeks later...
Hmm Anyone know which fuse/relay the rear centre and rear right brake light run off? Globe seems fine (Cant check centre), comes on with lights hwoever no brake light..
Cheers
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
