Hey guys,
Does anyone have the part numbers for nm35 A/C belt and Alternator belt?
The writing has worn off mine so makes ordering difficult without pulling them off to measure.
Cheers!
Ha, I was looking at belts today myself.
Genuine numbers were AY140-61175 and AY14N-4094E
Starter Motor 23300-AL600 (expensive new and ex Japan)
Starter Motor Brush kit 23378-EN20A also used in Australian model starters so readily available.
I did my wiper blades recently. Main thing with rear is to make sure that when you trim it down, there is something to hold the 'rubber' in place and prevent it simply sliding off the end, as the wiper arm holds the entire spine of the blade .... if that makes sense.
reason I say this is because it took me two lots of blades to find one that didn't just slip right off the end :S
Surely a r36 Passat is nicer in every aspect on comparison to a stock pm/nm35?
Apart from servicing costs and exploding DSGs that is...
And the fact they have tried to make a boring car cool and failed is also another reason to go stagea.
And when people ask you what you drive, R36 or not a passat is not a car you can tell them and be proud of it.
If you say stagea 90% of people dont know what they are. So your all sweet.
Edited by Howaitonaito
  • Like 1
some would say the same about our lunchboxes. Wpuld depend on individuals wants and needs.
Im after front wheel bearing part number and if there are any cars that have same wheel bearing.
I have a few aftermarket front wheel bearings here from the US... Nissan ones are just too expensive.
yeah i just purchased one from ebay but usa seller said week later he is sold out. What would you sell me one for scptty. Pm me
  • 5 weeks later...
Hmm Anyone know which fuse/relay the rear centre and rear right brake light run off? Globe seems fine (Cant check centre), comes on with lights hwoever no brake light..
Cheers
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
