There is no need, just clean the stainless mesh filter with brake cleaner. Use high temp silicone to reseal the sump, and don't do the screws too tight. I have never had to replace the gasket once.
If you need parts, there are some on Ebay locally it seems. http://www.ebay.com/itm/Premium-Auto-Trans-Filter-Service-Kit-KFS964-Trans-RE5R05A-Speed-5-/251422734703
Not sure if they are the parts we need though... No pics.
  • 3 months later...
Even the VQ35 starter sort of fits, it's larger and probably more powerful than the little VQ25 unit. The power lead is on a different angle and gets close to the hot side cooler pipe, but mine doesn't seem to be an issue as yet, wouldn't be hard to insulate the wire better though, or just tape it down.
I am interested to see if the VQ35 AFM will work too, as long as the voltage/airflow curve is similar it would be a great upgrade for those of us blowing AFM's constantly. I have new plugs in stock for them, and if you are tuning the car it probably wouldn't matter, but if the curve is out the stock ecu may not like it. Just need to spin a stock Stagea up on the dyno after fitting one before I can recommend them.
  • Like 1
will VQ35 AFM work with VQ25 stock ECU? I want to get stronger AFM with stock ECU, LOL
Not sure Yang, need to swap AFM's on the dyno and check out the afr's on boost. The low end will sort itself out using the o2 sensor.
Looking at the power the VQ35 afm's flow, they should be pretty close.
  • 4 weeks later...
  • 8 months later...
  • 3 months later...
  • 3 weeks later...
  • 4 weeks later...
  On 20/10/2016 at 11:35 PM, White_Stag said:
Hi guys does anyone have parts numbers for Rocker cover gaskets and seal for back of oil cooler. I'm having slight oil leaks.
Thank you!
Expand
http://jp-carparts.com/nissan/partlist.php?maker=nissan&type=153&cartype=7&fig=111&page=3
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
