  • 1 month later...
Hey all Anyone know what the part number for this bit of pipe that runs towards the back of the engine from the rad or if its an off the shelf part for that matter lol.Looks about 3 or 400mm long, the front of it in the red ring is abit stuffed
Thanks!
They are all a bit stuffed. They don't seem to leak though, no matter how bad they get. That pipe is designed to rust, sacrificial anode as part of the cooling system.
ah yep the thing is the front of it is rusting its starting to leak in the red ring end, got not much to clamp onto now lol
I have some s/h ones here that are quite useable, but get on Amayama and see if you can find the part, it may be cheap... Or not. :P
Bam. :woot:
Water pipe; 14053M
P/N; 21021AQ802
Price; $64.56 usd.
O-ring; 21049
P/N; 21049AE000
Price; $1.10 usd.
You're welcome.
The Russian version of epcdata has all the exploded diagrams, where the English version for whatever reason does not.
Eliminates all the guesswork.
All the prices are through Amayama, not regional Nissan dealers, so I'd suggest getting a few items to make the shipping worthwhile.
From Scotty's post in another thread;
M35 filter: 16400-4M405
Both look identical, and both have 0.1mm larger outlet holes than the stock one I removed.
I will suggest everyone replace the outlet Oring (P/N: 17049-4M400) when changing the filter,
Anyone have interior dimensions of either NM or PM35's?
I have seen them before for other Nissans - diagrams showing the whole car including interior and exterior dimensions.. No idea what manual/catalogue they would be from.
I had a mate translate some of the Stag owners manual. Engine oil change interval is 5000kms, not 10000, and it looks like the filter is every second change. Huge variation in oil viscosities is odd...Diff oil change interval is only 60,000kms, so i know what i'm doing on the weekend.
Going by thet table, it looks to me like the filter is every change (except for the diesel)... as it should be.
The oil they are going by there is the old Nissan semi-synthetic which would need a change every 5000kms.
Depending on the oil, you can actually do 10,000km oil changes, but you won't have much change out of $130-150.
  • 4 weeks later...
    • People think it's a waste of space, ugly, etc, generally associate "emissions control equipment" with "bad". These OBD1 vacuum-only systems I'm not a huge fan because I think they don't go far enough. They're wasting some of the fuel captured because they start purging as soon as the engine pulls vacuum. Later OBD1/OBD2 they put an electric purge valve on them to vent only when closed loop is active so the ECU will trim some fuel out. Even later OBD2 with zero evaporative loss the tank is 100% sealed from atmosphere until you run the engine or press the refuel door release. The tank has to take much higher vacuum/pressure spec but you never deal with saturating the charcoal canister and losing some fuel that way. The fuel also lasts as long as it would in a 100% airtight container which is nice when you're dealing with modern E10 pump gas.
    • If your luck is anything like mine, what happens is in the process of pulling hoses to get access to the one leak you create many more leaks because every o-ring was on the verge of failing and the strain of pulling it apart caused it to fail. Sometimes life is simple, sometimes you pay twice trying to save once. For the R33 you can still get most AC components from Nissan, I use nissan epc data or amayama to look up the part numbers and then search for the cheapest/most practical way of sourcing from there.
    • The dirty secret is there is nothing recyclable about the plastic bag or old plastic bottles either. Our local trash collection explicitly calls it out as hazmat in both cases. Oil-soaked rags + paper towels too. Oil-soaked cardboard is also not recyclable. The most common case of oil-soaked paper like that is pizza boxes, which are explicitly compost-only from the oil. To my knowledge hazmat oil contaminated plastic the only solution is either landfill or "thermal recycling". Most plastics in my experience there is slow permeation of the oil it's holding into the container so it's very challenging to get it 100% clean.
    • Yes, and since RAA insurance essentially being swallowed up by the same monster that is NRMA insurance and all those other clowns, they are no bloody good now either. We dropped RAA insurance for the house a little while back because they lost the plot.
    • I can tell you now, good luck if you're with NRMA (NSW equiv of vis RACV and QLD RACQ). Because NRMA are freaking horrendous to deal with for claims, even with a normal road car. Not to mention even more BS when they're in the wrong and didn't cancel a policy etc when they were meant to and make you jump through hoops for things.
