Mine is still going I think, I lent it to Jase a year ago. 13 years is pretty reliable if you ask me.
If only Nissan still sold that original part, not the part they sell now which only lasts a few weeks. (if you are lucky.)
My aftermarket ones seem to be lasting fine Leon... :)
That's a good point Scotty, & you are totally correct. Just because a heap have failed in the last 12 months or so, doesn't make the AFM any less reliable then a cam sensor, window motor or electric seat switch. They're all going to be getting close to the end of their life after 13 years or so.
I've got 2 original AFM's & given how little distance my car gets driven, I reckon I'm set for another decade or 2 :)
it happens every now & then in between gears. I'll be looking into the Kompact BOV asap.
Where does the factory boost guage connect up ? Mine is is always reading in the neg & occasionally goes to 0.
Is there a guage you can swap in it's orig place without going all ricer & mounting one.?
sensor of a black oval box in engine bay next to wheel arch. Pull it apart and resolder the points.
  • 1 month later...
To follow on from the Facebook argument from last night... M35 part required for when the time travel switch fails on the clock assembly.
http://www.oreillyauto.com/site/c/detail/EB00/121G.oap?ck=Search_121g_-1_-1&keyword=121g
  • Like 3
Does anyone have the part number for the lower ballpoints from Nissan and a price? I recently sourced some v35 ones and installed them and now front end has constant cracking in the front end.
For ballpoints, you can't go past BIC. :P
  • Like 4
Assume you mean ball joints yeah? the lowest ones on the steering knuckle?
Nissan doesn't sell it separately, they'll only sell you the whole assembly. Have to go on ebay.
Was it these ones you bought?
http://www.ebay.com.au/itm/2-FRONT-LOWER-BALL-JOINT-Set-NISSAN-SKYLINE-V35-01-07-/190450769457?pt=AU_Car_Parts_Accessories&hash=item2c57c01e31#ht_2375wt_1180
DAmmit I bought them too, seems like some other haven't had issues with them though...
  • 3 weeks later...
Microguard Pure-Tron Cabin Filter: B74946N025
This probably won't help many. I found that my Stagea didn't use the standard cabin filter instead in it's place is a Microguard Pure-Tron:
http://www.calsonickansei.co.jp/english/products/accessory.html
When i'd pulled the glove box etc.. out i was presented with this:
Amayama have the replacement filter for ~$65. Looking for alternatives.
Yeah it's an Ioniser, with a filter sitting in it. It's the first one I've seen like this, all the previous ones i've seen / dealt with have been the parcel shelf models in Skylines and 'rollas.
The standard filter doesn't fit, it's way too big (i purchased one prior to pulling the car apart). The ioniser takes a up about half the height and the filter sits within it's frame making it smaller in all directions.
Size comparison (Stock filter bottom):
I had the same as this on my ARX. Gave up trying to find a replacement that fitted, and when back to the XTrail/Maxima sized one...
In addition, the actual ioniser screen was discussting, covered in cigarette smoke like rubbish... Actually found it all in the garage over the weekend and tossed it..
G'day all,
I'm chasing part numbers and possible price of valve stem seals for vq25det engine. Any help would be great.
It's an engine out job, are you sure it's the valve stem seals? Have you tried leak testing them or something?
It's just the PCV valve, it sucks crankcase vapours into your engine and overnight they condense and run down onto the valve. It burns off as you take off in the morning.
I wouldn't worry about it at all. I ended up fitting a catch can to my PCV line, but it has to be sealed as it's in vac. It worked well to stop it, but it's a pain to drain.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
