I am new to this forum, and recently bought a 1998 Nissan Skyline R34, but it did not come with the manual book with specifications, I was wondering if anyone knew if there was a website for an online Manual? or a place i could buy one? If there is already a thread concerning this, please direct me too it, i had a look with no luck. Thanks in advance!!! :)
Nissan R34 Workshop Manual in Japanese
I bought these at AutoWorld Books at Rushcutters Bay Sydney.
Occasionally Hanzie the odd Manual might come and go at Haynes Manuals at Fairford Rd Padstow NSW
Rare to come across nowadays.
I've compiled a set of PDF's and docs on the R34 that people have found useful:
http://www.mediafire.com/download/kfp0g2vulagm88v/R34.rar
Contains:
A book of skyline stuff (lol)
R34 10000KM Maintenance
R34 ECU Pin outs
R34 GTR MFD Manual
R34 Interior fuse box english translation
R34 NZDM brochure
R34 Service manual
R34 Stereo pin outs
Nissan Paint code index
Nothing near a users manual but you'll definitely pick up some stuff from the lot. General operations of the vehicle, just post a thread here :)
Skylines Australia - The Imported Manual-less car owner's manual*
*Certain excerpts may or may not be correct. Some advices and instructions may lead to more headache and frustration.
Hey,
Here is the link i was talking about, you can read it online and such. But it looks like others have beat me to it ;)
Anyway here you go incase you still needed or just want to have a look see http://www.scribd.com/doc/5332929/Nissan-Skyline-R34-Workshop-Manual-English
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
