Willis's Garage Cleanout!
Location; Sydney NSW (Western Suburbs)
Ok so i have just sold my skyline. Trying to clear out some space. Send any offers through via PM.
Regards, please don't msg me asking if i have thing's that are not listed. Thanks.
Engine / Driveline;
RB20DET Engine (no turbo, no coilpacks, no power steering pump, no aircon compressor and no starter motor) comp test 130 PSI across cold, removed for RB25 conversion. - $500
RB20DET Gearbox (average condition, second gear synchro is pretty shot it's fine when rev matching though.. gearbox whine in 1st and 2nd gear's) removed for RB25 conversion, includes RB20 Clutch Slave - $300
RB20DET Driveshaft (good condition) removed for RB25 conversion - $150
RB20DET / 25 S1 Throttle Position Sensor - $40
RB20DET Radiator + Shroud - No leaks, no corrosion, removed for Aluminium Radiator Upgrade - $100
RB20 Clutch Master Cylinder - $60
RB20 Clutch Slave Cylinder - $20
Exterior;
Front bar as pictured (pretty average condition, would suit drift pig) - $40
LH + RH Doors (Gunmetal Grey), average condition, includes windows and everything else found in the door, includes door skins - $150
LH + RH Guards in average condition (Gunmetal Grey)- $150
R32 GTR N1 Headlights, Immaculate - $250 pair (no mount for grill, can be bought from nissan for cheap..)
post-75263-0-47983800-1369092612_thumb.jpgpost-75263-0-82795200-1369092620_thumb.jpgpost-75263-0-81054900-1369092629_thumb.jpgpost-75263-0-02744200-1369092638_thumb.jpg
Exhaust;
RB26 FRONT PIPES (twin 2.5" inlets to 3" rear) contact damage with ground - $50
3" Jasma approved cat-back suit R32, includes catalytic converter - $150
Suspension;
HCR32 OEM Camber Arms - $50
HCR32 OEM Castor Arms - $50
Driftworks HICAS Lockout Kit, BYO bolt's etc - $150
GK tech adjustable castor arms V2 suit s13/180/r32/a31, billet 7075-T6 aluminium construction BRAND NEW IN BOX - $120 (rrp 150)
Braided Brake Lines - $60
Driftworks Solid Subframe Risers (new in box) - $80
Interior;
Skyline Door Trims (kick panels), both in good condition - $20 pair
Sparco Pedals + OEM Pedal Box's, Clutch, Accelerator and Brake - $120
R32 GTR NISMO CLUSTER 260kph / 10k rpm ODO 78568 - $300
R32 Ash Tray - $30
Apexi Pen Turbo Timer - $50
Drift Button GK TECH - $10
Wheels;
Work VS-MX 17 x 8 +22 and 17 x 9 +22 pcd 5x114.3 & 4x114.3 17 x 8 +22. No buckles, wheels have rash as pictured. These are genuine 3 piece items, i bought them with the intention to rebuild with larger lips. The front's require spacers to clear 32 GTR brakes.
The 8's come wrapped in 205/40r17 as pictured. The rears are in similar condition, have more dish and no tyres. - $1200 ono
post-75263-0-37142700-1369093212_thumb.jpgpost-75263-0-80237600-1369093219_thumb.jpgpost-75263-0-96142600-1369093227_thumb.jpg
Kosei 17 x 8 +38 and 17 x 9 +38 wrapped in 235/45r17 & 255/40r17 Bridgestone Adrenaline's (tyres are down to wear markers, camber worn, wheels have rash, structurally sound) - $700
post-75263-0-23864400-1369093235_thumb.jpgpost-75263-0-79649800-1369093241_thumb.jpgpost-75263-0-89136700-1369093249_thumb.jpgpost-75263-0-49608100-1369093472_thumb.jpg
Random parts;
Trust Front Mount I/C NO PIPING - $150
R32 GTR Resistor Pack (to run 32 GTR Injectors on a RB20) homemade - $50
SCA Engine Crane as new! used once then stored in garage! - $250
K&N Intake Pod Filters suit RB26 - $50
S13 / 180SX SR20 Oil feed hardline, not leaking bought as a fix for my old leaking one - $30
Thanks! :)
Willis.
https://www.sau.com.au/forums/topic/425621-williss-garage-cleanout/
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
