Willis's Garage Cleanout!
Location; Sydney NSW (Western Suburbs)
Ok so i have just sold my skyline. Trying to clear out some space. Send any offers through via PM.
Regards, please don't msg me asking if i have thing's that are not listed. Thanks.
Engine / Driveline;
RB20DET Engine (no turbo, no coilpacks, no power steering pump, no aircon compressor and no starter motor) comp test 130 PSI across cold, removed for RB25 conversion. - $500
RB20DET Gearbox (average condition, second gear synchro is pretty shot it's fine when rev matching though.. gearbox whine in 1st and 2nd gear's) removed for RB25 conversion, includes RB20 Clutch Slave - $300
RB20DET Driveshaft (good condition) removed for RB25 conversion - $150
RB20DET / 25 S1 Throttle Position Sensor - $40
RB20DET Radiator + Shroud - No leaks, no corrosion, removed for Aluminium Radiator Upgrade - $100
RB20 Clutch Master Cylinder - $60
RB20 Clutch Slave Cylinder - $20
Exterior;
Front bar as pictured (pretty average condition, would suit drift pig) - $40
LH + RH Doors (Gunmetal Grey), average condition, includes windows and everything else found in the door, includes door skins - $150
LH + RH Guards in average condition (Gunmetal Grey)- $150
R32 GTR N1 Headlights, Immaculate - $250 pair (no mount for grill, can be bought from nissan for cheap..)
post-75263-0-47983800-1369092612_thumb.jpgpost-75263-0-82795200-1369092620_thumb.jpgpost-75263-0-81054900-1369092629_thumb.jpgpost-75263-0-02744200-1369092638_thumb.jpg
Exhaust;
RB26 FRONT PIPES (twin 2.5" inlets to 3" rear) contact damage with ground - $50
3" Jasma approved cat-back suit R32, includes catalytic converter - $150
Suspension;
HCR32 OEM Camber Arms - $50
HCR32 OEM Castor Arms - $50
Driftworks HICAS Lockout Kit, BYO bolt's etc - $150
GK tech adjustable castor arms V2 suit s13/180/r32/a31, billet 7075-T6 aluminium construction BRAND NEW IN BOX - $120 (rrp 150)
Braided Brake Lines - $60
Driftworks Solid Subframe Risers (new in box) - $80
Interior;
Skyline Door Trims (kick panels), both in good condition - $20 pair
Sparco Pedals + OEM Pedal Box's, Clutch, Accelerator and Brake - $120
R32 GTR NISMO CLUSTER 260kph / 10k rpm ODO 78568 - $300
R32 Ash Tray - $30
Apexi Pen Turbo Timer - $50
Drift Button GK TECH - $10
Wheels;
Work VS-MX 17 x 8 +22 and 17 x 9 +22 pcd 5x114.3 & 4x114.3 17 x 8 +22. No buckles, wheels have rash as pictured. These are genuine 3 piece items, i bought them with the intention to rebuild with larger lips. The front's require spacers to clear 32 GTR brakes.
The 8's come wrapped in 205/40r17 as pictured. The rears are in similar condition, have more dish and no tyres. - $1200 ono
post-75263-0-37142700-1369093212_thumb.jpgpost-75263-0-80237600-1369093219_thumb.jpgpost-75263-0-96142600-1369093227_thumb.jpg
Kosei 17 x 8 +38 and 17 x 9 +38 wrapped in 235/45r17 & 255/40r17 Bridgestone Adrenaline's (tyres are down to wear markers, camber worn, wheels have rash, structurally sound) - $700
post-75263-0-23864400-1369093235_thumb.jpgpost-75263-0-79649800-1369093241_thumb.jpgpost-75263-0-89136700-1369093249_thumb.jpgpost-75263-0-49608100-1369093472_thumb.jpg
Random parts;
Trust Front Mount I/C NO PIPING - $150
R32 GTR Resistor Pack (to run 32 GTR Injectors on a RB20) homemade - $50
SCA Engine Crane as new! used once then stored in garage! - $250
K&N Intake Pod Filters suit RB26 - $50
S13 / 180SX SR20 Oil feed hardline, not leaking bought as a fix for my old leaking one - $30
Thanks! :)
Willis.
https://www.sau.com.au/forums/topic/425622-williss-garage-cleanout/
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
